length of burnisher shaft
>Andy Lincoln has sent me one of his carbide tool nozzle burnisher shafts, and I'm getting ready to put it in a handle. Sometime. When the round tuit inventory is good. It's 4" long, 5/16" diameter, tapering in the last 3/16" down to 1/8".
I see burnishers in the catalogs with long shanks, like knife steels; but I also see photos of people holding a burnisher like a paring knife, with the thumb on the end of the scraper positioning the burnisher. And it seems that I'd want that small-diameter portion available for concave scrapers, like the French-curve type (or, as Lee Valley puts it, the "shmoo" type). Is there any advantage to having the full-shank portion any longer than, say, 1/2" or 3/4"? If so, why, and what's the optimum length?
Re: length of burnisher shaft
I like mine short and skewed. *LINK*
David Barnett - SW Florida
>I have both long and short. Although you can get an easy visual read of the angle for the burr, I prefer short burnishers such as the Harris Tools skewed one-hand burnisher. Simple, intuitive, repeatable, easy to make. I have one with a round carbide 1/4" tool bit and another with a ruby laser rod.
I seem to recall a patent scuffle over this idea, but could easily be mistaken.
Short burnisher
I meant...
>"Although you can get an easy visual read of the angle for the burr WITH A LONG BURNISHER,... "
And I also meant...
>This link. Sheesh. Early senility is setting in.
See?  *LINK*
Burnisher
>Hi Bill
I made a burnisher out of a carbide rod (donated generously by Tony Z)and deliberately kept it short. The issue of being able to judge angles did not enter my thinking - the shorter length (about 4") does not make this more difficult. I just prefer the "delicacy" of the feel this burnisher imparts over the longer, heavier Crown I have used for some years.
I feel that I have more control with the lighter burnisher. I am sure that, in part, this comes from the thinner rod. More probably form the highly polished and slippery carbide. I just love this little tool.
Here are the two together:
Jack Guzman from Maine
>I got one of Andy Lincoln's burnisher rods.I just inserted enough of the rod into the handle so it would stay. Length has never been an issue for me.---Jack
>The way I use a burnisher I would not have enough control to use that little taper right on the end of the shaft. I put the taper into the handle when I made mine and have about 3" or so of burnisher in front of the handle. I tend to move the burnisher diagonally across the scraper edge to burnish. The 1/4" diameter has worked fine for french curved scrpaers as well. These bits make a nice burnisher so if you need one I will e-mail the round tuit right at you; that or a kick in the pants maybe, whatever it takes ;)
Tony Zaffuto
>Derek and others,
I've made more than a few burnishers, short and long, thin and fat. What I've found (purely a personal opinion) is that for me, a shorter, thinner burnisher seems to work a bit easier.
The material for these is carbide, which has a natural lubricity to it and is polished beyond the typical HSS steel or drill rod material typically used.
One of these days maybe we'll get a "scientific" study done by one of our ambitious Aussie friends (Derek, you listening????). I'll volunteer to supply some burnisher material out of various metal types. Might even be able to find a piece of ceramic material, but the usefulness would be governedby the surface finish.
T.Z.
Here 'tis
>Too danged cold out there for the kitchen remodeling work I planned to do, so, after finishing mounting the new fence on the routah table and cleaning up the bench, I made the object below.
Carbide tube courtesy of Andy Lincoln. Handle courtesy of an old meat grinder, one of six in the junk pile at a garage sale, from which I salvaged possibly useful parts before recycling the metal. "N" drill to enlarge the hole (which makes it .010 undersize for the carbide tube), a little 5-minute epoxy in the hole, some pounding, and Robert's my uncle.
I would recommend
>That you make the burnisher handles square or octagonal instead of round. When it rolls off the work bench it can only be dropped once if it made of carbide.
Stephen
I'll keep that in mind for the next one
>This handle's not quite as round as it looks, though - there are apparently subtle flats on it, as it tends to wobble to a stop.
Re: I'll keep that in mind for the next one
Dan Donaldson
>Try just putting a flat on one side of the round part of the handle.
>Hi Tony
The idea sounds great! It would make a good excuse (if one ever needs such a thing) to arrange another workshop - in Perth, but all are welcome :). I will contact you at a later date and remind you of your generous offer (again!).
Many thanks.
