New blade for an old Plane (woodie)??
hb
HB
>Tis the year of the project tool. I'm finally tired
of seeing all these bargain tools around here that
need this or that to be useful, so I'm tackling them
one at a time. (SWMBO got a good look under the bench
the other day - sheesh can't a guy buy stuff now for
tomorrow?)
The current project is a jack sized woodie with a
tote. Plane is in perfect shape and actually appears
to be solid boxwood.
Doesn't look like it was ever used, really. The
probelm is that although the original wedge is in
place, the blade assembly consists of an unmarked cap
iron that seems about the right size for a Stanley #2
smoother, mated to a stanley blade off a # 5 Jack.
It's a franken blade for sure.
How exactly do I get a new iron for this plane? Do i
just need to measure the width of the blade bed and
then order a cap and iron from Rev Hock in the
appropriate width? I'm getting hung up on whether or
not the wedge will work or if I need to supply more
information to the blade and cap iron maker.
Thanks.
HB
Re: New blade for an old Plane (woodie)??
Wayne
>I just finished making a wood plane and didn't even use a cap iron and it works as well as the metal ones that have a cap iron, throws a beautiful curl. You might have to make another wedge but that isn't hard.
James Watriss
>Well, if the blade fits in the width department, then you know you need a 2". If it's not wide enough, you could need a 2 1/8, 2 1/4, or wider.
What I would do:
-measure the plane width, and cut under to one of hte above sizes, provided you have enough room. Figure maybe 1/16 or less on either side of the blade would be optimal. There are options if you opt for a narrower blade than that, though... I'll get to that.
-Test the wedge: Some wedges bed well with cap irons, some don't. A cap iron with a curved front on it will emulate a tapered iron, which clearly has advantages. (An aftermarket cap iron from Hock or L-N won't, it makes for a parallel iron.) If the iron beds fine with just the blade, sans cap iron, then you have the option of either using just a blade, no cap iron, or use one of the aftermarket cap irons from hock or L-N.
-look up irons on either the hock site, or L-N. L-N stock irons are thicker, which might help you out in terms of blade stiffness. It also might not leave enough room for the wedge to get all the way in. Tough call.
-if you go with an iron that's narrower than the mouth width, because it's an odd size, I'd drill and add some wooden pins to help with lateral adjustment. The idea is to drill into either side, about 1/2" up from the flattened sole, with the targeted hole being half in the bed, and half in the area where the blade sits. Then glue and hammer in some pegs until they're just barely touching the side of the iron. This will keep the business end of the iron in place while you tap out the lateral adjustment. Otherwise, even if you go through all the time and trouble of properly bedding in the iron, it can pivot farther up the bed, which can make the corners stick out even more... it's easier to adjust with those side pins in place.
If the prose is lacking, let me know, I'll post a picture or two.
>HB
I would avoid modern parallel blades. It is more likely that your plane is designed to use a tapered iron. These can be about 3/16" thick at the bevel and taper to 1/16" at the other end. More information about the maker and, better still, a picture posted here, would help in deciding this. I would be surprised if it is not a tapered iron, however.
Where to get them? Look on eBay - they are cheap. Cheaper than a blade from LN, LV or Hock. Even purchase a sacrificial plane-with-blade if the body is shot but the blade is good. Made sure of the width needed. Make a new wedge to hold it later.
Regards from Perth (presently vacationing in Tasmania)
paul womack
>I'd use eBay; old blades are available, ad postage even from the UK will be reasonable.
This appears helpful:
http://stores.ebay.com/The-Old-Plane-Iron-Shop
Also, A search:
plane (blade,iron) (antique,old,vintage)
gave some useful looking results.
BugBear
>HB
hb
Plane is by "J. Engle"???
HB
>Thanks for the input fellas. Regarding the maker of this plane, the only name that appears on it is "J. Engle" at the toe.
But I always thought that was just the owners name. It could be a one-off made by the craftsman, although the apparent lack of use that it has seen puzzles me - for all the work that must have gone into it, it's hard to believe it wasn't used afterwards.
I'll post pictures this evening or tomorrow morning for those that are interested.
Thanks again.
HB
Tell you what...
Bob Hackett
>If it takes a tapered iron and I have a spare then pay the postage and it`s yours.
From what I`ve seen most US iron/chip breaker(cb) combos use a short screw and a tapped cb while the ones from across the pond use a longer screw tapped into a raised boss on the cb or a square nut brazed onto it.this requires a relief groove in both the frog bed AND the back of the wedge.Just something to think about before paying all that postage from the UK and finding out it`s not a drop in fit.
Mainely,Bob
hb
Re: Tell you what...
HB
>It's a us made plane then since only the frog is relieved for the screw in the chipbreaker.
I'll have to post a picture spo you guys can see what it looks like in its "as found" condition.
Yup, Let's see it !
Todd O. Cronkhite Maine Native, Presently Away
>SWMBO got a good look under the bench the other day
OH, THE HUMANITY!!!
Just an idea, but I think it would be a god idea to get a common piece of flat iron and go shaping and fitting and use it as a pattern for the donor blade.
T.O.
