bedrock 602/need parts
Jack from Copperhill
>Hi Everyone - I picked up a sweet 602 at an auction awhile back for $5.
Trouble is it's missing the levercap, chipbreaker and iron. Would anyone have these parts they don't mind parting with or know someone?
Thanks
Re: bedrock 602/need parts
Well there's the problem Jack...
Scott Burr in Ben Lomond CA
>The parts are going to cost more than what you paied for the plane its self. You'd be better saving your money and sending the plane to me.
A $5 602...Yep Jack, YOU SUCK!
Square or round, user or collector?
Neal White
>There is some justice in this. See, while the rest of us hate you for finding such a gloatable item, you will be loosing sleep because you can't complete it, LOL. Depending on what you want to do.... If you are trying to keep it "as built" and it is a round side, you are in for a long search. They had lever caps with "Bedrock" or some such cast into them, and are unique and hard to find. The square sided ones had the same lever caps as the run-of-the mill #2. Still not a common item.
What I'd do if it was mine is find a dog-meat #2 and rob the 4 parts you need: the blade, the lever cap, the chip breaker and the screw. That's still a tall order because people have been collecting them lately, since #1 prices are out of sight. If it is a user, you could get the blade, chip breaker and screw from Lie Nelson or Lee Valley (I think), but you are still without a lever cap.
Have patience. I had a similar experience with a 605 round side with a broken & welded frog. It worked fairly well and rode around under my car seat for several years (you never know when a piece of wood will happen by that you need to examine the figure). Then, when I wasn't looking for it, a correct frog jumped out in front of me for a modest price, and everyone lived happily ever after. Good luck!
Re: Beep beep!
Dave Mount
>Talk about a drive-by gloat. I hope you're not expecting any sympathy. . .
If it's a user, I wonder if you could get by grinding down a levercap from a #3. There's only 1/8" difference in width between a #2 and a #3, so you'd only have to take 1/16" off each side (in theory). I'm not privileged enough to own a #2 anything much less a 602 (well, OK, I have a #2 pencil. . .), so I'm not able to evaluate the potential for coerced compatibility (e.g., the distance from the leading edge of the lever cap to the screw).
Good luck in your hunt.
Dave
>It's a square side and I'd like to add it to my collection of planes. I've seen these parts go from $100 to $300 on ebay. I was hoping some sympathetic collector with a junk 602 would step forward in my hour of need. :(
J.
Todd Hughes
>Look on the Ebay and you will find what you need sooner or later...The blade assembly is the same as a regular no. 2 of course and is easy to find. I just sold on the Ebay a nice older no. 2 blade for $25.00 and it's chip breaker for $20...If I had not seperated them probably would have went cheaper.[By the way if you are selling a no. 2 in most all cases you will do MUCH better breaking it up for parts...don't think I will ever sell a complete one again] Sold the lever cap from this plane for about $55. It was an older non nickled cap.
Not all flat top bedrocks took the regular Stanley marked lever caps. The flat top bedrocks came out in 1911 and they did not switch over to the plain Stanley lever caps till 1923....in between they used ones marked Bedrock with the early ones having the Stanley R&l co Bedrock logo.
If you need a 602 cap that is marked bedrock then that is much harder to find...and more expensive. Don't know but If I had a bedrock 602 lever cap I would figure I had a $200-$300 lever cap ....Todd
>There is no such thing as a sympathetic collector. If adding to a "collection" I would try to find the correct parts for it. If you need help knowing what to look for post pics of the plane and there are several people with the book and knowledge that can help you out. But so far as getting one cheap, consider yourself very fortunate to have found the plane cheap. I think the 602 is selling for some pretty heavy pocket change; they didn't make the 601 you know. You got the expensive parts, and as mentioned you can proabbly find the #2 parts relatively inexpensively. It's probably going to be a lot of work to find though; I'll quadruple your money and take on the headache myself, just send me the plane.
