An easy way to apply shellac
Bill Tindall, E.TN
>When I started using shellac I looked for recommendations on how to apply it. Various expensive brushes were recommended. After spending a lot of money on brushes I concluded that if this was the only way to apply shellac I was not going to be successful using it.
It does spray successfully, but it is more difficult to spray than lacquer.
Then I was shown the ease at which it can be applied with a wad of wool wrapped in a cotton or linen cloth.
I was doing the insides of some boxes today and there on my bench was a foam brush I had used to apply some "synthetic" milk paint ( have I ever said how much I hate real milk paint or that I am cheap. I had washed out the 5 cent foam brush for reuse). I tried it for the shellac, a one pound dilution for box and drawer insides.
This foam brush worked very nicely for the shellac. It held a bunch of shellac, the key to successful application. And it applied it smoothly and evenly. While I have not used it enough to decide that it is better than a wad of wool, it is certainly worth further evaluation.
Re: An easy way to apply shellac
"RJ" Whelan
>Bill ... the alcohol should have destroyed the foam brush in pretty short order. You might try an experiment with your frequently washed brush: just let the tip rest in alcohol for about 3-4 minutes and see if it starts to break down. If it doesn't, I want to know where you got those brushes ...... rj
It held up just fine
Bill Tindall, E.TN
>I am not sure where the brushes came from. It is a 1 " brush and I think it came in a cheap pack of assorted brushes.. I used it for a lot more than 3 min. I supposed the foam was a urethane and there is no reason to expect urethane to dissolve in ethanol. Maybe they aren't normally urethane.?.
Having discovered this application devise I would be crushed to find out I have the only brush on the planet that works. If so I will make some out of some sort of alcohol resistant foam.
Latex paint has tens of percent organic solvents that are vastly more aggressive than ethanol. Traditionally this solvent was an alcohol-ketone and it gave latex paint its traditional odor. Yet these solvents don't attach these brushes.
the handle?
Bill Tindall, E.TN
>over on the other side they said alcohol will dissolve the handle/foam adhesive. My shellac never wicked that far so I don't know about that problem.
Re: I've had this experience -- try cold temps
Dave Mount
>Just because they're cheap, easy to use, and "tidy", I sometimes use foam brushes for quickie applications of shellac. However, there is definitely an interaction between shellac (plus alcohol) and the foam brushes I get. Almost immediately you can see the foam matrix "swell", such that the body of the brush is thicker and wider where it has been exposed to shellac. If I continue to use it, it starts shedding bits of foam into the finish. As a result, I don't use foam brushes for final coats or any application of much size/duration. The interaction appears very much to be with the foam, not the adhesive. I have no idea what the issue is chemically, but I've got plenty of empirical experience that something does indeed happen.
One of the best techniques I've found for being successful brushing shellac is to do it in the cold. Shellac is the only finish that is compatible with cold temperatures (e.g., less than 50 F). Because shellac cures solely by evaporation of the alcohol solvent, you can use it at any temperature at which alcohol will evaporate to an appreciable degree.
But more than just being cold tolerant, cold temps make shellac much easier to apply, because it slows evaporation of the alcohol and gives you much more "open time" before it starts to tack. This is a huge help in eliminating brush and lap marks, a familiar thing to most who try brushing shellac. Doesn't help much in the summer, but in the winter, cold is your friend.
Best,
Dave
Re: Thin coats
barryvabeach
>Bill, at the Colonial Williamsburg FWW conference a few years ago Mack Headley gave a demonstration on applying shellac. He kept a jar of shellac on a bench with the ugliest brush I have ever seen, and every fews hours, he would stop whatever woodworking he was doing and slapped (and I mean slap)on a coat of shellac , IIRC 1 1/2 or 2 lb cut. Every 3 or 4 coats he would use a scraper to smooth the dried finish and then would continue applying thin coats. He said that once he got to about 12 coats, he then used a rag and applied a 1 lb cut and used that to "smooth" the finish, then once fully dried he rubbed it out. The conference was only 3 days so he didn't complete it, but showed us a piece that he had started a few days before the conference and it was stunning. From that I learned - if you use that method, you can ignore most finishing rules - his brush was rough like a glue brush, he made no real attempt to apply the finish evenly,and he made no attempt to keep the item protected from dust. What saves it is that you keep abrading as you go to remove nibs and defects and the last coat is mostly alcohol and then you can rub that out to a gloss finish once it is dry. The only downside, of course, is that procedure takes 3 to 4 days, at least, and I don't have that patience.
What is cold?
Bill Tindall, E.TN
>This is a concept I vaguely remember. I was cutting wood in a flannel shirt today. Its coming back to me now. Something about a report that propane might not vaporize if it got much colder. OH, bad memory, must not think back that far, frozen feet. Heading south, feeling warmer. Ah, better memory...........
Re: What is cold?
Dan Donaldson
>cold and snow are both four letter words ;-)
So is "rain"
Bill Houghton, Sebastopol, CA, gopher geysers!
>I was stunned when I lived in the Midwest by the concept of a warm rain. California North Coast rains are usually just this side of sleet. I'd almost rather have it cold enough to sit there on the ground when it falls than have it trickling down my neck at 34 degrees.
but you don't have to shovel it
Bill Tindall, E.TN
>And.....Now that I am retired if it is raining I just go hunting another day when its sunny!
True
>but when you see it running over your foundation from the crawlspace, you sometimes wish you could.
