Ever wonder how the old timers...
>ran a bead of glue.
This is a glue spoon, copied from an illustration in Salaman's Book. It holds 3 teaspoons of glue and works for both hot hide glue and liquid hide glue.
Overall length is 8 inches.
Stephen
Re: Ever wonder how the old timers...
Bill Houghton, Sebastopol, CA, gopher geysers!
>A lot classier than a stick of scrap from the shop floor.
Wiley Horne
>That's a perfect instrument. Deep so it will hold the heat til the very last moment, yet will pour a fine bead if you want. Lot better than the plastic cough syrup measurer I've been using.
Wiley...wondering where to find a spoon like that.
When do you need a bead of glue?
Pam Niedermayer - Austin, TX
Re: When do you need a bead of glue?
>The glue spoon works for tongue and groove joints or when you need to get a quantity of glue on the surface of a joint prior to brushing.
The spoon is no substitute for a brush to work the glue on both surfaces, but it delivers the glue where needed.
Stephen
>Wiley,
Our resident tinsmith made that one for me, I'll ask him what he would charge.
Stephen
Thanks, Stephen.
I'd cast them...
John in New Mexico
>Of course, that probably wouldn't fit your particular paradigm (ahhh, reviving a buzzword!), however it would work better. More mass, slower cooling. Steel or iron would probably be most effective, being a bit less conductive - though that works both for and against. So perhaps bronze would be a better choice... pretty (sell more), easier to cast, and sure to annoy various used tool dealers- marks up the wood y'know!
Neat spoon. Can't say as I ever did wonder about it, but, sure enough, where would we be without our plastic squeeze bottles? Using neat little spoons.
In addition to what Stephen said....
Wiley Horne
>anytime you have a long edge to get hot hide glue on, it's an issue, because everything depends on laying the glue down quickly, and in a bead if possible, because the bead will hold its heat better. Like Stephen said, you still brush, but it works better (for me) to distribute first, in a bead, and then brush in a second step.
Some sort of a ladle--and the one Stephen showed seems perfect--lets you get the glue down in a line, still holding its heat, and from there you brush quickly and set the mating piece into place right behind the brushing.
Couple of examples.....gluing cockbead strips into their rebates. Or making one-off banding, where you want to glue contrasting strings--ebony or holly--on either side of a pictorial band you've made up. And then later, when it's time to glue those bands onto the edges of a table top. In all these cases, a ladle or spoon lets you accomplish the distribution step with a minimum of heat loss.
Wiley
Wiley Horne
>Stephen,
If he makes another run, please consider me down for it! Might be some other takers on the forum, also.
Great post! Thanks,
Wiley
Re: In addition to what Stephen said....
>Thanks, Wiley. I've been using mostly cold hide glue (the glue pot is sitting there waiting for the new shop) and rubbing long joints; but I see how this could be very useful. Good point about a bead being able to hold the heat better, hadn't thought of that.
Pam
Gary Karner
>You can put me down for one also.
Me three please!
Brad in Ottawa
James Watriss
>Me, too...
