Re: Holding down boards? What I ended up with
Dominic Greco in Richboro PA
>Hello Everyone,
Wow, did I have a great day in the shop today! I spent a good portion of it flattening some 4/4 rough sawn cherry boards. I first cut them to length and then used a set of simple shop built battens to plane "against".
The battens were so simple to make that I made (2) of them. I bought some 3/4" hardwood dowel from Lowes and then used some scrap Maple and Walnut. I think they took all of 15 minutes to make.
Only one small problem. The holes on my bench are just a tad off from being equally spaced. So the battens work on some of the holes, and not on others! So it was actually a good thing that I made two.
I was about to make that pop up stop like that suggested to me on another woodworking forum when I realized I already had something I could use. My Tail Vise! I just got a piece of scrap and dropped it in the vise so that it's top was just under the thickness of my stock. It made a perfect stop. So between the batten and the stop, I was all set.
I made the battens last night. So I was all set for today's exercise. I started with my Scrub plane then moved to my No7. As work progressed, I started using more and more of my planes. I just wanted to see which ones I preferred for this operation. Well, I think the Scrub Plane, my Union No7, and my 604 were my favorite ones to use. Plus I finally got to use my LV Winding sticks that I got for my birthday last year.
Thanks again for all your help and suggestions.
See ya around,
My ugly mug
Dominic
Re: Re: Holding down boards? What I ended up with
Oh look at those sweet shavings!
Scott Burr in fridgid Ben Lomond, CA
>Looks like someone had fun indeed! Glad to see ya got the hold downs/batten problem all figured out! Whatcha making?
Jim Shaver Oakville, Ontario
>Great Post Dom,
I love seeing simple process presented so well.....makes sense to me to consider this myself.
Take care,
Jim
Hi Scott
>Scott,
Thanks! BTW, I'm making a hand tool cabinet.
See ya around,
Dominic
Thanks Jim!
Hi Don!
>Looking good! Your gonna have one nice tool cabinet, even though your using SoildWorks:^)
Please keep us informed on your progress!
Solid Edge!
>Scott,
I used Solid Edge my man! Solid EDGE! That is like calling a Ford a Chevy (or vice versa!) :>) Seriously, those two programs are so much alike it's scary. They should be. Solidworks uses the Solid Edge Kernal (internal program core). When I interview for a job they usually ask which software I know. When I say Inventor, ProE and Solid Edge, they usually say, "That means Solidworks as well."
I cut up all the plywood parts and have dado-ed and rabbit-ed them. All I need to do is add the hardwood trim. Hence the need for the cherry. I know, I know. Cherry on a hand tool cabinet! I'm resisting the urge to go "Studley crazy" on my handtool cabinet. But every once in a while I splurge. Now I need to find some wide veneer for the front door panels. Or maybe I can resaw some walnut and book match them? :>)
See ya around,
Dominic
Nice work Dom
Dave Anderson NH
>I too have used stops like yours for years and they work great.
As for your cabinet CAD drawing, knowing you, it's already time to rethink it. How about twice as wide, a bit higher, and with some provision for further expansion. You just gotta know you aren't going to have enough room and it's going to be full as soon as it's built. ;-)
I can always build 2!
Re: Solid Edge!
Scott Burr in Ben Lomond CA
>Not only did I misspell your name in my post, I insulted your software as well:^(
Nothin' wrong with using cherry or walnut IMHO. My first tool cabinet was made from them. The two woods go great together.
Please keep us posted on the progress.
BTW, Dave's right.
