ADVERTISE HERE - FREE TRIAL
wooden plow revisited
Jack Guzman from Maine
>Awhile back I asked questions concerning the repair of a worm eaten plow fence off a Mathieson plane. I sliced 3/16"off of the face and filled the remaining holes with filler made by rasping the removed piece of fence into dust and mixing it with hide glue.Then I glued a 1/4" piece of boxwood tro the face and cleaned up the edges.
After cleaning all the remaining parts,I assembled the plane and inserted the 3/16" iron.I chucked a piece of pine into my vise and made a groove. It is everything I expected.No tearout and just a clean smooth operation.Quickly executed groove.Making this groove with a 044 is troublesome.I'm always fussing with the fence alignment.The screws slip.The plane hurts my hand.It is hard to keep it perfectly vertical due to the shape of it.The 044 is good in a pinch but not the ideal tool for the job. The Mathieson is.
I know it's a little rough but I think it's a pretty tool.I love the feel of it. The wedges that hold the fence arms go a little deep and are a little chewed up on the ends but I'll keep them as long as it works ok.At least for now.I hate to change anything on it.
thanks Bob Dunning---Jack
Re: wooden plow revisited
first groove
Re: first groove
Todd O. Cronkhite Maine Native, Presently Away
>Jack, I think your repair is MAAAAAAAAAAA VAAAAAAAAAAAAA LISS. I see that you didn't try to color the box wood to blend in the orginal fence, which of coarse is of no matter. Sometimes I like the repair to show just kinda' show that it has been repaired a.k.a. brought back from the bring. Looks like it works quite nicely as well.
It is a beautiful looking plane and has a beautiful flowing patina. If it feels as nice as it looks, then I know it's comfortable.
T.O.
Re: first groove and some meanderings
Wiley Horne
>Jack,
Congratulations on bringing this fine plane back to life again! That first groove is clean as a hound's tooth, which of course is the reward for your skill.
These wooden ploughs must have set the high-water mark--or one of the high-water marks--in the development of the plane. I recently got a screw-arm W. Marples & Sons, Sheffield, of'n the Bay that is more fun than most fun things I can think of. The blades themselves are worth a chapter in someone's book. I like that they're snecked; that they're laminated; that they're slightly elliptical so they become sprung once you insert the wedge; that they're double-tapered and relieved in their depth to make clearance for the cut. The slightly tapered sides keep them from munging up the surface of the groove. The lengthwise taper + the sprung wedge = very solid blade set, and without bashing on the wedge. That's a lot of technology and a lot of machining and manufacturing work, for an ordinary trade item.
Thanks for sharing your very neat Mathieson. Let us know if you come across more cutters for it.
Wiley
Groovy Dude!
Scott Burr in fridgid Ben Lomond, CA
>Looks nice Jack-n-stein. You did a fine job brining new life into it.
Like I need another plow plane like a hole in the head, I've been eyeballin wooden ones lately the handled ones look comfy to use.
Is it difficult to set the fence on it?
Re: Groovy Dude!
>That's the easiest part.Everything about this plane is easier to use.---Jack
Sweet!
>I guess I realy NEED another plow plane;^)
Pretty & nice. Great job with the restoration.
VLParisian
