Brace Till Ideas?
Brace Till Ideas?
Brace Till Ideas?
David Miller from Iowa
>Please email or post photos of your brace storage apparatus. I used to keep about 20 of them as shown in the photo, but I want to line up maybe 50 of them hanging from the ceiling. I need a till to hold them securely because they all will be chucked with bitstock tools and will have different centers of gravity - I can't just hang them from a single pipe. Maybe 2 parallel pipes?
thanks
Re: Brace Till Ideas?
Re: Brace Till Ideas? *LINK*
Bill Houghton, rainy Sebastopol, CA
>Darrell from Oakville posted his a couple of years back. See link.
Dense pack brace storage
Here's mine
Scott Burr in fridgid Ben Lomond, CA
>Open to changes or complete overhaul. You choice!
Yo Bill, beats a bunch of string!
Just kiddin;^)
>Mine is simmilar to this except that the braces hang upside down instead of right side up.
>OK as a relative newbie to hand tool work of this caliber, why do you need more than a few brace's. I only have 2, one I bought because it doesn't have the ratchet which lets met cut the holes more accurately. No more than I use them it's easy to change bits. Of course as a turner I have 4 chucks because I don't want to change the jaws but that takes a lot more time than changing a bit in a brace. Just a curious question. Always willing to learn.
Re: The reason is...
Kevin French, Antrim, NH
>Because their THERE!
They are cheap, I find them in the dump, so their FREE for me.
And it's another slippery slope.
The ones I have hanging are a crude form of Scott's
Jack Guzman from Maine
>What Kevin said,they're plentiful.I stopped grabbing them because I already have storage problems.I keep one with a countersink in it.One with a 3/4 boring bit for dog holes(you never know where you're going to need one)One with a screwdriver bit for stubborn screws.There are six or seven more(not to mention the eggbeater drills)that I keep nearby set up for various jobs.I hate constantly changing bits in chucks so this is a good solution.The only downside is the space problem.I'll fix that too,eventually.---Jack
Less is More
Jeff S.
>John,
You don't.
After aquiring a Yankee 2101, I no longer had any use for another brace.
Less clutter, less stuff to take care of, store, etc.
Simplify, simplify.
Because...
>You NEED different size sweeps. You NEED both ratchating and non ratcheting ones. You NEED different chuck types, Spotford, Lion, Holdalls, etc. Then you NEED brest drills for the big jobs. Corner drills and angle adapters for those trick situations. Then you'll NEED egg beaters for the medium and small jobs and persision drilling.
and you forgot
Bruce, a MN Galoot
>you NEED one for a square drive bit, one for a phillips bit, and one for a torx bit. Beats the dickens out of having to change bits each time there's a different screw to drive
says Bruce, who keeps one loaded with a torx bit and one with a square bit all the time (don't use phillips screws much anymore).
Geez Scott.......
Todd O. Cronkhite Maine Native, Presently Away
>Can you slop any more grease onto the 'Slope for poor ol' Dave? Try to at least show some Mercy won't cha' ;~)
I've talked to myself down to 5 braces to be hung nearby for ready use, with the rest in drawers on Standby Status.
T.O.
Normite Neanders
Jeff S.
>You guys are worse than Norm... who has a routah for every bit! :-)
Re: Geez Scott.......
>I haven't got a numb'a but now that my rack is full I'm not going to add more room to it.
I don't know if I have all the drill Scott advocates. Not sure I need that many. I with you on the variety, but not the variations.
Aww Come on guys!
>I still need to fill out the Fray/Spotfords.
Oh, I forget the whole Wimble side of things too;^)
Pass the grease please Todd...
Re: Less is More
>One Yankee 2101, yep, that would do the trick. What would happen if you saw one at a garage sale for $5 or flea markets for $10? How many #2101 braces would you have then ;) I am up to 3 or 4. I took a milk crate full of braces to an auction last year, so I am down to about 10 or so because I had to keep the good ones.
