Homebuilt lathe 1of 5
Todd O. Cronkhite Maine Native, Presently Away
>OK, here's some pics of my homebuilt lathe as per Bill's request. I'm going to do my best to include allot of the demensions and other info just in case somebady may be interested in building one. If I leave anything out, and I probably will,or if you have any questions feel free to ask for more info or pics.
I built the lathe in '95 from the plans I found in a book that was put out by WOOD magazine.
-All the plywood used was 11/16" thick
-I ordered the hardware from the company that is listed with the plans. The hardware included the 2 #2 MT shafts, the pulley on the shaft, the 2 headstock bearings, and the belt. Cost was #200
-The motor is a flea market special 1/2 h.p. 1725 rpm 110v single phase.
-The motor is bolted to a board, with common strap hinges bolted to the board, then to the backside of the base. It's own weight keeps the belt tight.
-The bed rails are 70" long, by 7 1/8" wide.
-Each rail is made up of 3 strips of 11/16" plywood
-The gap between the rails is 2 7/8"
-The bolts are common carriage bolts.
-The towers that hold the shafts are 5 1/2" x 5 3/4"
-Between the rails is a block that is 10 3/4" long
-The towers extend 11" above the rails, and 3 14/16" below in the center of the rails.
-The center of the shafts are 8 3/4" above the rails.
-The shafts in the tail stock are threaded thru two common floor flanges that I rethreaded with a 1" 8 thread per inch tap.
-The distance between the center of the motor shaft and the headstock shaft is 25"
-The two bases are hollow and are 27 3/4" tall, at their bottoms they are 15 1/2"x11 3/8", at the tops they are 11 1/2"x8 3/16"
-I had to extend the rod of the tool rest to accomadte the extra dept of the rails. I did this by merely using a thread union and a lenght of all thread.
-I had to make riser blocks to put beneath the tool rest itself to raise it up to reach the shafts. It's a bit of a pain when it's time to reposition it, but for the add'l depth that I can turn it's worth it. The riser blocks as you can see are just two pieces of 2x4 screwed together.
It's been a good lathe, and don't regret building it. I like the idea that by building it myself I can change the dimensions of it if I so choose.
T.O.
