Some quantitative data on diamond sharpening
Bill Tindall, E.TN
>The following is in response to an earlier question on sharpening and what is "best". What I do seems fast and convenient to me, but then I don't have anything to compare to, except myself. While I might claim it is fast and convenient, without data no one else can compare either.
I needed to bevel the top edge of a box I am building and while I would have cheerfully done the bevel with a router, I didn't have a bit that would do the angle I wanted. I knew a razor sharp iron would be needed on the end grain or the end grain would wind up fuzzy and not stain well. I did not want to sand the resulting planed bevel or it might round over and destroy its crispness.
My LN low angle block was the weapon of choice for this task and it was "dull as a hoe", as they say. Since I needed to sharpen it I thought I would keep track of the effort and report.
Step 1 I began on a wheel, 100 grit very soft bond. My grinder is variable speed (VFD drive 3 phase) and I run it about half of 3600 rpm. I ground up to the edge, leaving about 0.010" or less of the original bevel at the edge. Basically, I nearly removed the bevel resulting from the last honing. I use very light pressure to keep from burning so this operation took two or three minutes (I failed to think to time it). (I think I may move back to 80 grit some time in the future to make this part go faster.)
Step 2 I took 10 pull strokes on a 6" very fine fixed diamond stone lubed with water. This operation resulted in about a 1/32" bevel. (this stone does not result in grit carry-over to the 1 micron like a 15 micron loose diamond charged stone would. Others don't worry about carry-over)
Step 3 I then took 10 pull strokes on a 12" cast iron plate charged with 1 micron diamond, lubed with WD40.
Step 4 I rubbed the back of the iron on the cast iron to remove any wire edge that didn't sharpen away in step 3.
Step 5 I tested sharpness. (I admit this may be a strange test) I see if I can effortlessly clip the tops of finger prints off. The edge failed this test.
Then I did what I should have done to begin with. I examined the edge with a 10X lens to see its condition. I can't emphasize enough how useful a 10X lens is to assess edges. I could see that to begin with the edge was crumbled in places and quite rounded over from wear. Because I only ground to the bevel in step 1, step 2 was the only step that affected the original "dead" edge. Step 2 removed too little material and didn't remove all the damaged/worn edge. Even though I felt a wire edge forming after this step it wasn't enough. The lens would have shown me this fact, had I thought to use it.
So I repeated steps 1-5 except this time in step 1 I ground all the honing bevel away and examined with the lens to see that all the dead edge was gone before proceeding to step 2. The edge passed step 5. I got a bright surface on the end-grain bevel. I was reminded how effortlessly a SHARP plane works. Note to self: sharpen more often, especially after using plane on shooting board.
