holding down long/wide boards?
Dominic Greco in Richboro PA
>Hi Everyone
OK, I've got a newbie style question here. I started working on my tool cabinet over the weekend and need to surface some rough sawn cherry. Before I hit the slippery slope, I'd face joint one side and then throw it through the surface planer. But now I work while my daughter is napping or asleep and need to use a less noisy method for surfacing wood.
I know the basic steps to surface, and have the proper equipment. But what gets me is how to hold the board down to the bench!
Trapping the board between a dog mounted on my bench and my tail vise holds it. But not as well as I like. Also if you use too much pressure, the board will bow up.
Using a hold down (like a Veritas) would work. But that means that you would not be able to get to the part of your board where the hold down is.
Is there a shop built hold down you can use to trap the board by the sides and hold it while you have access to the entire top? I've seen something like this for small parts. I checked the internet and found a really interesting set of simple stops I can make. But I wonder how effective they'd be when using a scrub plane, or surfacing cross grained with a camber bladed jointer. They look like they'd work fine when the wood has one side surfaced. But what happens when both sides are rough and have bows or dips? How the hell do you hold it down then?
What method do How do you hold down wide boards while surfacing?
Can someone give me some pointers here? I'm not above spending some time making some bench accessories or turning up my bench. Hell, I just took 30 minutes of "project time" to make a new shoot board as well as spending 45 minutes scraping the top of my bench to make it as smooth as possible!
See ya around,
Dominic
