A handle for my burnisher
Dominic Greco in Richboro PA
>Hi Everyone,
I just whipped this up yesterday while puttering around in the shop. I had the Hock burnishing rod for a while but never got around to putting a handle on it. So after I finished tuning up my #12 and #80 scrapers yesterday, I scrounged around and found a small scrap of Bocote and a 1/2" Brass Compression Nut.
In case you are wondering, the flats on the hex nut could have been "turned" smooth to present a nice clean surface. But then I wouldn't be able to unscrew the ferrule and remove the burnisher if I ever wanted to make a new handle for it.
After turning a tenon to size fit the inner diameter of the nut, I removed it from the lathe and threaded it onto the handle. I then un-thread it, and treat the newly "cut" threads with CA glue. This is a trick I use all the time with my turning tools. I tend to make new handles for a lot of my tools since the factory supplied ones are always too light.
The handle has several coats of Danish Oil. This was allowed to dry overnight. Afterwards it was buffed with a Beall Buffing system and given a coat of wax
Thanks for viewing.
See ya around,
Dominic
