In the "never thought of that" category...
Denis Ch�nard, Orl�ans, Ont.
>Some things should be obvious, but I must say that this never crossed my mind...
Say that you want to use your block plane to work on some end grain. Problem is, you have a regular angle one, not a low-angle model. Workable, but not ideal...
Grind a 15 degree bevel on the blade, and add a 10 degree back bevel. You now have a plane with an effective angle of 35 degree, lower than a low-angle block plane in its "standard" setup. The included angle on the blade remains at 25 degrees, so it will be as durable, and the resulting 10 degree clearance angle is amply sufficient.
Say that you do have a low-angle block plane, but would like an even lower angle of attack. Same principle but less leeway, grind at 20 degree and add a 5 degree back-bevel. You get a 32 degree angle of attack, yet still with an included 25 degree angle, and a clearance angle of 7 degrees. Depending on the species and thickness of cut one might get away with an even lower angle of attack, with clear pine for instance one could get away with a 20 degree included angle, 27 effective, by grinding a 15 degree bevel. That's not far from a regular chisel in terms of effective angle...
Now I didn't think of all that. I found the info in the Veritas MK. II power sharpener manual... Totally obvious once you read it, but I must admit that this wouldn't in all probability have crossed my mind (even though I use the ruler trick on all my bevel-up planes)...
Now, instead of the ruler, make a notched wooden block that sits 1/4" high and 1/4" from the stone edge (for 3" wide stones such as the Nortons), and you get the "block trick" that will give you the 5 degree back bevel (which would be hard to do consistently freehand). As with the ruler trick, this back bevel can be very small, like 1/64" long.
Of course, this will also work with bevel-up planes. I think I'll do that with the 25 degree blade that came with my Low Angle Jack, that blade is only used for end grain anyway...
Back to this manual, while not as comprehensive as Leonard Lee's book on sharpening, it is nevertheless a very good guide to sharpening most woodworking tools...
DC
