We value your privacy.
I'm making another Greenland style kayak paddle, which starts as a cedar 2x4 with vertical grain & gets long tapers cut on the flat faces. Usually, I'd do this on my buddy's jointer, but he is out of town. I picked up my grandfathers 8" draw knife & put a serviceable edge on it, and it seems perfect for the job.
I'm now putting a nice edge on it, but how do I use this thing? Once I make friends with it, I'm sure it will be faster than the jointer, & more fun to boot.
Thanks!
ChuckS
Here is a photo of my dad in a boat he built, using a Greenland paddle. Sorry I don't have a better paddle pic.
>Grab a piece of scrap wood and go to it. It doesn't take long to figure out what works.Drawknives are great for removing alot of material fast. Don't expect it to do everything though. That's why they make spokeshaves and rasps.---Jack
>And once you get the hang of it a la Jack's advice, you may want to learn some subtleties. If so, time to check out the Boggs dvd on drawknives, spokeshaves, and horses available from LN.
>Nothing to it Chuck, sharpen the edge and then as Jack says "go at it". It can be used with bevel up or down and can take some aggressive, hogging cuts or much lighter shaping cuts depending at the angle you hold it at when attacking the wood. When taking lighter cuts try to attach the wood with the blade a bit skewed to it, and make slicing cuts.
Also, as Jack said, the drawknife is used for initial hogging off of stock to initial shape, then go to your finer tools such as spokeshaves and rasps. The drawknife is the scrub plane so to speak, the shopeshaves and rasps are the smoother planes.
I like the paddle that you pictured, but I would think that you'd be better off started off with a 2x6 vs. a 2x4.
Stay away from that jointer, it's dangerous, noisy and dusty. A very foul machine IMO.
>I think I will like this thing! I was able to rough out the blank in a few minutes, about the same time as a jointer. I HATE jointers for the mentioned reasons- LOUD, MESSY, etc.
Unfortunately, I'm well acquainted with LN planes & such :-)
>Yes, your right chuck, I forgot to mention SLOW. All that danger, noise, mess and slow to boot. What a loser of an expensive machine that can be so easily replaced by a few inexpensive, safe ,quiet and very portable handtools. Can't say that the drawknife isn't messy because it is,but at least the mess from it is much easier to clean up. No worries about getting muliple blades set in the same plane when they are removed for sharpening.
>I was lucky enough to take a class with Brian Boggs over the summer. Wow, can that guy use a drawknife.
His tuning and sharpening methods may differ from what other people do. He goes through the normal bevel and flat honing, but he also subtly rounds the flat face towards the edge. So the bevel, I'd guess, should be sharpened a little on the shallow side... figure 25-ish degrees, or a little less if you're working in something really soft. The basic theory is that it will enable you to steer more easily in and out of a cut. He said to round it very slightly, try it out, round it a little more, and keep doing so until you hit something that is very controllable. There's a little back and forth on the stone to change the amount of rounding involved, obviously.
Brian could hog out massive amounts of waste one minute, and then angle the blade to make a shearing cut, and take some very fine curly shavings off of the same piece of wood. It's really something to see him work. But he's very capable of both very quick, dirty, rough work, as well as very fine, precision shaping, with one tool.
He holds similar philosophies on tuning bevel-up spokeshaves. In his mind, they're basically built like drawknives with a depth limiting feature to prevent huge chunks being removed.
>...identifying another "must have" tool, one really need a shaving horse to efficently use the draw knife and related tools with depth stops. I have made several using Drew Langsner's (google him) pattern - see pic. Also, I saw a cool shaving pony on this board a while back (see link).
>As others have mentioned, this is a fairly intuitive tool. My observations:
1. As always, grain direction matters. The moment when you get a good cut going and realize the grain direction is such that it's headed WAY past your layout lines...not one of those memories you'll cherish.
2. I find short, choppy strokes most effective for roughing out. I even find myself doing a kind of karate grunt at times, though this could just be middle age.
3. Once you get comfortable, it's really quite astonishing how effectively you can smooth wood to the layout line, using slower strokes, more like petting a cat.
>The Boggs horse is alo very nice, but that's not to say that you need to buy the pre-made fancy one. Brian wrote an article a while back, and he actually recommends building your own, and customizing the height to fit your own size. According to the article, he suffered some lumbar injuries at one point, and the design of his horse makes it VERY back friendly.
The pony looks cute, but looks to me like one would have to hunch over to use it, which would be pretty uncomfortable over the long run.
