Trouble with a 605 and blade advancing
Dominic Greco in Richboro PA
>Hi everyone,
To celebrate the upcoming 11 days of vacation, I decided to work on some hand planes. Two days ago I worked on a 604 and it came out so sweet that I decided to start on a 605C I had waiting in the wings.
It was in pretty decent shape and only needed some surface rust removed. However, in my typical anal fashion I took the entire thing apart and wire brushed, buffed, and cleaned all the parts until all the rust was removed. I oiled all the parts to neutralize any contaminants from my hands. Then I set them aside for a day to allow the oil to penetrate.
Today I decided to assemble the parts and lap the sole. That went as easily as could be. No problems with assembly and no issue when I lapped the bottom. Nothing is easier to lap than the sole of a corrugated plane!
The problem started when I decided to try a Hock blade in the 605C. I originally purchased this blade to use in my 605C, but I had installed it in the 604 and was amazed at how well it performed!
When I put the blade in, it acted like the the frog had to be backed off (to increase the mouth size). I backed the frog out (I now love that Bedrock mechanism!) but was unable to get the hock blade to advance. In fact, when I took a test cut it was acting like the blade wasn't seated properly. I took the blade out and examined the frog. Nothing seemed amiss. I reinstalled the old blade and got the same problem!
What bothers me is that I had no problem at all with the 604. I got that baby up and running in no time flat. The 605C should have been the same. And the hock blade works excellently in the 604 (So much that it may end up staying there!)
Has anyone had this happen before? This is my first bedrock, so I'm not as used to this frog adjustment mechanism as I was with the Bailey's. Are there directions for it's use?
See ya around,
My ugly mug
Dominic
Re: Trouble with a 605 and blade advancing
Wiley Horne
>Dominic,
In the Bedrock or Bailey adjuster, there is a little bent finger, or tang, that has to reach through the blade and engage the chipbreaker. The adjuster screw makes the tang move, and the tang's engagement with the chipbreaker is what moves the chipbreaker/blade assembly (I apologize profusely if this is all totally obvious to you!!).
Reason I mention all this, is that it sounds like the tang is not engaging the chipbreaker slot. Check to see if it is. If it isn't, then you need to move the chipbreaker relative to the blade until the tang engages. Or else the blade is too thick for the tang to reach through and engage the chipbreaker. How thick is this Hock blade?
Wiley
>Hi Wiley,
Thanks for responding so quickly!
This is you standard Hock replacement blade. Not sure of the blade thickness. But this blade is manufactured to be a replacement blade for Stanley's standard factory one. And the first thing I checked was if the yoke was engaging the chip breaker.
After I cooled down a bit I went out side and checked the 605 one more time. I removed the lever cap and blade assembly and checked the frog. It turns out that the frog was a bit too far back, and that the jack screws were loose. This combined to make the blade assembly lift from the frog just enough to cause a problem. After re-setting the frog, and then securing the screws it looks like the problem went away.
Thanks again.
That was Easy...
VLParisian
See what happens when you give ourself a time out
Scott Burr in Ben Lomond, CA
>Sometimes it's best just to walk away and give it a beak. Yes one must tighten down the frog screws after adjustment;^).
Personally I'd leave the Hock blade in the 604 and use the stock 605 balde with a good camber on it.
Wiley Horne
>Dominic,
Good work. I knew you knew all that elementary stuff, but just couldn't think of anything else right then.
But this is an excellent thread, because I would venture a WA guess that half the people who own bedrocks, or bedrock type planes (LN, Clifton) have at one time or another left those hold-down screws a little loose after adjusting. That's usually the first time you discover that those two screws are what is holding the entire mechanism of the plane together, by indirect action.
Wiley
Totally agree!
>Scott,
You can say that again! Knowing when to walk away from a problem in order to get your "head right" is a hard to do sometimes. But it always pays off.
And I totally agree with you about keeping the Hock blade in the 604. After working with the 604 for a while I found I really do prefer to have the hock blade in that plane in lieu of installing it in the 605.
Truth be told, I absolutely fell in love with my 604 after I tuned it up. NOW I know why everyone raves about Bedrocks so much! In a head to head contest between my 604 and my Bailey No4, the 604 is the winner hands down.
See ya around,
Dominic
Re: Totally agree!
>I like the Bedrocks because of their history, and the fact that they cost more than the normal Bailey plane. I have to spend more money in order to have one, so it must be a better plane. It's a different feeling when I pick up a bedrock plane to use; it's heavier, and I know I spent a ridiculous amount of money for it, so it's more fun to use. I buy a Hock iron or two for myself every year for Christmas. I figure it will last me a lifetime, so they keep adding up. I have one in my #112 scraper plane, my 604-1/2 and 603, and bought one just this year for my 604. It's still setting under the tree till tomorrow morning ;) Next year will be my 605 & 605-1/2. I also have a Hock marking knife that is schweeeet! No spoke shave blades; yet.... That man sure is a getting more than his share of my paycheck ;)
