legs not level
legs not level
legs not level
chichi
>I made a small stool and the legs are not level. In the past, I have used a spirit level and established the plane of the shortest leg by making a mark on each leg level with the bottom of the shortest leg. I then removed the extra length from the 3 longer legs. For whatever reason, this never worked that well for me.
Is there a simple dummy proof method to levelling legs?
Thanks,
Bob
Re: legs not level
Re: legs not level
markfromsacramento
>Put the stool on your table saw with the longest hanging off the edge. Mark the amount that it hangs over the edge and plane this amount off--voila, it's level!
Re: legs not level
Re: legs not level
Pam Niedermayer - Austin, TX
>You need a simple compass with pencil on one leg. Set the stool on a level surface and set the compass to measure the distance from surface to shortest leg. Then scribe that measure to the other legs with the compass.
Pam
Re: legs not level
another method
Mike Schwing from Md.
>In addition to those posted - there are always multiple ways to skin a cat.
Attach a piece of sandpaper to a flat surface, like an assembly table or a tablesaw top. Rub the tip of the longest leg back and forth on the paper, checking it regularly, till it is no longer the longest leg. Takes a bit longer with multiple legs, but still works.
Re: legs not level
Re: legs not level
Don Pierson
>Next time make a three legged stool...then you don't have to worry about level.
Re: legs not level
Re: legs not level
Adam Cherubini
>What I do is invert the object then mark each leg with a story stick. When this doesn't work, I put the object on its legs, shim one leg until the top is where you want it. Then using a small stick or a pencil- anything with uniform thickness, mark that thickness on each leg, up from the floor.
That's how I do it.
Re: legs not level
A friend of mine...
>Made a kitchen table and asked me how to make all of the legs level.
I suggested that he cuts off the longest leg until it is level.
If you are good you will end up with a kitchen table,
if your skills are somewhat less you will end up with a coffee table,
if your skills are not that good you will end up with a pallet.
Good Luck ;-}
Stephen
Re: legs not level
Re: A friend of mine...
Todd O. Cronkhite Maine Native, Presently Away
>and if you're slkills are like mine you'll end up with a cutting board! }:~[
T.O.
