Samauri Plane Blades?
Tom MacGregor
>Has anyone tried a Samauri laminated steel replacement plane iron? The local tool shop is stocking a 2 inch size and I'd be interested in feedback if anyone's tried one.
Tom MacGregor
Re: Samauri Plane Blades?
Richard L. Darin
>In my opinion among the best, easy to sharpen and hold a edge as well as or better than anything I have tried. For best results use a thick cap iron.
>Hi Tom
I have one in my Stanley #7 and one in my #18 block plane. They are excellent blades - they get sharp and stay sharp. The only downside is that they are the same thickness of the original blades and do not offer the type of damping one can get from thicker blades (from other aftermarket manufacturers). So if you are after a sharper and longer lasting edge, then get one. On the other hand, if you feel that the plane is not performing optimally, they will not fix it for you.
