Stanley/Bailey #7 Blade
Nick Tuzzolino
>Just obtained a nice Stanley/Bailey # 7. Slight surface rust, non-exposed portions in mint condition. What would you recommend for a beefy replacement blade?
Re: Stanley/Bailey #7 Blade
markfromsacramento
>Hock
Jim in Burlington Ont.
LV A2
>Those blades with the back lapped. Make short work of sharpening.
Dean J in MN
>Is the orig. blade missing?
-Dean
Wiley Horne
>Nick,
Couple of notes from my experience tuning up two Bedrocks some years ago--605 & 606. I adapted a Holtey blade, whose thickness was approx. 0.11", on the 606, with just a little loss of adjuster motion. But a 1/8" blade was thick enough at 0.125" that it would have required brazing an extension onto the tang to keep the adjuster working. My suggestion would be that if you go fatter than the 0.095" Stanley replacement blades made by Hock or LN (or others), it would be good to try the thicker blade first to see if there are going to be issues.
The second thing I found was that upgrading the cap iron had a very good effect. After replacing the cap irons on the 605 and 606 with the then-new LN upgrade cap iron, I went back and replaced the cap iron on an LN4 as well--this had a good effect, even though the plane had a 1/8" iron. You might consider whether you want to replace just the blade, or both cap iron and blade. And save the factory ones, of course, to keep the plane whole.
2 cents.
Wiley
P.S. Another thing I found
Wiley Horne
>was that the factory setup on both planes worked well. I was just having fun ekeing a little more from the planes. I think you would get longer planing runs from a modern replacement, which might be useful for face planing. But for edge jointing, the factory equipment will be fine IMO.
Wiley
Nick Tuzzolino
>No. It is all intact. The original blade just looks kind of wimpy compared to my LN low angle jack plane.
Thanks!!
Nick Tuzzolino
Dean J in MN
>Sharpen that stock blade and give it a whirl. You may be surprised how well it works. Not knowing the types of work you do, nor the lumber you use I can't say if the extra $$$ you spend upgrading will really have any effect. If the stock blade turns out to work, spend the money on wood! You can never have enough wood!
-Dean
Keep the Original
Jeff S.
>I'm with Dean.
I work with relatively straight grained domestic soft and hardwoods and have yet to find the need for an aftermarket blade.
In fact, I would be interested in some of those Stanley, or better yet, Record blades, that some folks are replacing.
Jeff
You can't wrong with any of these...
Scott Burr in Ben Lomond CA
>The LV ones are nice because the backs are ground flat. Very easy to polish up. The LN and Hock blades require a bit more work to polish up the backs. The LN and Hocks are available with thicker chip breakers (back irons) they are well worth the investment IMHO.
