A55 Smoothing Plane
Plow fence repair---new issue
Jack Guzman from Maine
>I tackled the problem of the wormholes in the fence to my Matheson wooden plow plane.I started be removing about 3/16" from the face of it. This revealed the fact that the worms had burrowed alot deeper that I first thought.I made some wood flour from the piece I removed ,mixed it with hide glue and filled the remaining holes.I didn't want any hollows behind my repair.Then I glued a 1/4" slice of boxwood to the face and shaped it to match what I removed.The repair looks good. Now to a new problem
I started to clean up and reassemble the rest of the plane.This plane came with one iron. I bought a set on ebay to fill it out. I assumed that as long as my irons had the groove in them they should all pretty much be the same. Wrong.These other irons don't fit.The taper is more pronounced.As a result the grooved side only makes contact at the end and the wedge doesn't fit right.It doesn't contact the iron at the top.
How do I get replacement irons that fit? Is there a particular maker I should look for to match a Matheson plow?---Thanks---Jack
Re: Plow fence repair---new issue
It Might be possible
>To make a replacement wedge (keeping the original of course) to use with the new blades. The wedge can be made with the appropriate angles, etc.
I had a plane with a problem similar in that the set of blades were just a little too thick and came in contact with the front skate. I carefully removed the front skate, filled the holes and set it just a bit forward. It was slightly undersize so the movement didn't make it project out of the front of the plane body.
Don't know if that will work but it is much easier than working iron.
Stephen
Adam Cherubini
>You could make a new wedge just for those irons. Another maker's irons might work better.
You have many alternatives. What I did is bought a complete set of irons and then tweaked my wedge to fit that set.
But honestly, I very rarely use anything but the 1/4" and sometimes the 1/8". I really don't need the other irons and I doubt you will.
Adam
Hi Jack, The problem with the irons is...
Scott Burr in Ben Lomond, CA
>Did you ebay English or American irons?
Their not the same. For the most part English irons fit English planes and vise-versa. For your plane you need irons made for an English manufacturer.
I wanna seee pics!
I'll post pics...
>once I finish. The repair needs a little fine tuning.I didn't want to stress the glue joint til it was dry.True,I'll probably only need a couple sizes but you never know. Besides, one of the ones I need is one that doesn't fit.I think I'll look for English irons.But for now I'll try it with a new wedge.I can't wait to make some grooves!!
Thanks folks---Jack
ThomD
>What about planing out a wedge so it has a bow on the contact surface and only contacts high and low.
>I will be making a modified wedge so I can use a few of these irons but that won't help the iron fit the plane.They don't make full contact with the bed of the plane because of a greater taper. I'm sure this will cause vibration in use.I have no intention of modifying the plane body.So I will be searching for different irons.---Jack
Wiley Horne
>Jack,
I know how you feel, wanting the right irons for the plane, especially after you've gone to the effort of repairing the fence.
If I were you, I would go for a home run, and try to find Mathieson irons.
First, check US and UK ebay.
Second, I suggest writing Andy Stephens at Inchmartine. Does that sound like a Scottish single malt whiskey? He is in Mathieson country, and might have some Mathieson irons near to hand. Here is his website:
http://www.toolbazaar.co.uk/
Third, Tony Murland is worth a shot, and he might well know if Sheffield irons are likely to fit your Mathieson planes. Just google Tony Murland for his website and contact info.
2 cents. Caution, however: A set of irons can cost more than the original plane, but as Adam says, you can collect them in 1's and 2's.
Wiley
Feel like traveling north?
Bob Hackett
>If so I can loan you a handful of assorted brands so you can see what fits and possibly broaden your horizons,maybe even trade afew.
Mainely,Bob
>I already started the search for Mathieson irons. Almost won one but got sniped. That is alot of useful information.I'll check those sources.Thanks Wiley---Jack
Re: Feel like traveling north?
>Actually ,that would be a fun trip. Unfortunately I don't get around much anymore,especially once the snow flies.Thanks for the offer Bob.However,I do believe that the internet will make it possible for me to find Mathieson irons.I just have to be patient and persistent.---Jack
irons cost more than plane--in memorium
>Seeing that the plane cost me nothing,it won't be such a big deal spending a few dollars on irons. A fine gentleman(and galoot)that I met in connection with the local museum gave me the plane a couple months before he died of a heart attack.
His name was Bob Dunning.I only met him this summer. He had a great job. He did antique house restorations.He was rebuilding window sashes using hand tools. This plane is kind of a tribute to him.I won't ever get rid of it. I'll use it in honor of a good man.I only wish I could have had more time to get to know him.---Jack
Adam Cherubini
>Jack,
I don't understand what the taper has to do with the bed. The bed should be flat, the iron is flat. The taper effects the wedge, no? Maybe I didn't understand the problem. You are putting the wedge on top of and in front of the iron, right? The iron should have a groove that rides on the front skate (which sits slightly proud of the bed).
Adam
Paul in NJ
>Hi Jack,
I think you need to be careful if you are going to buy new irons. I have 10 or 12 irons from different Sheffield makers and they all vary in size, there does not seem to be any standard. The body widths vary from 1/2� to 5/8� with most around 9/16�. The thickness of the cutting end varies too. I would tend to think that the angle of the taper would be pretty close between them, certainly within a degree or two. What I did notice is that they are all bowed in length. I think this might be on purpose. When you tighten the wedge, it should compress the bow and tightly hold the iron against the skate. Perhaps a proper fitting wedge would seat your irons better. A piece of beech from a hopeless plane would work well. Use a candle to soot the back of the iron when fitting the wedge; it will help you sneak up on a good fit.
Good Luck!
Paul Dzioba
inexperience
>Adam,I read your post then read Paul's and I hurried to the shop and checked.I've never handled a woodie plow before. The irons weren't contacting the bed because they are bowed.The groove contacts the skate at the bottom and only the very top of the iron contacts the bed.When I insert the wedge it gets tight at the bottom before it contacts the iron at the top....until I tap it in.Then everything starts to fit better. I need to spend more time playing with this plane. I may not need any other irons---Jack
>Paul,I think you may have solved this for me. I may not need any other irons. They are indeed bowed and the wedge appears to fit better when I drive it in. I gotta play with it some more. Thanks---Jack
Bummer, Jack!
Roy Anderson
>When I got my plow plane off Da Bay it came with no irons, but was otherwise in semi-great shape. I bought the next set of irons that I saw, also on Da Bay and they, out of pure dumb luck, fit perfectly.
Considering all the strategizing and scheming and sniping I do for other things, this impulsive buy worked out better than anything else I have done.
Sorry yours is being such a problem.
Don't you mean 'back skate'?
if that's what it's called
