Record 043 Plane Follow Up
Jim Shaver - Oakville, Ontario
>Thanks to several people here I followed up on some leads and now am the owner of a Record 43
Photo Sharing and Video Hosting at Photobucket
I am pleased with the purchase, although I have not tried it out yet it looks perfect for my needs. It also came with three cutters.
My shop is a bit cold right now and my hip is not ready for shop work so working with this plane might have to wait till spring.
Thanks again for the help.
Take care,
Jim
Re: Record 043 Plane Follow Up
Bill Houghton, sunny Sebastopol, CA
>Well, shoot, Jim, my shop's just fine, once the morning coolness is over. Send it down to me, and I'll take care of it for you for the winter. I'll even send you the occasional e-mail showing the shavings.
Darrell in Oakville
Darrell in Oakville
>Last time I had to take some tools on the road I discovered that the little #43 plow is a real gem in the toolbox. You can (of course) plow grooves with it, but you can also cut rabbets. A block plane will hog off the bulk of the rabbet after plowing a groove. Dadoes can also be cut with the 43 if you score the shoulders first. Can be a bit of a mess if you're not careful, especially with the potential for blow-out at the end of the dado, but it can be done.
The flooring project would have been a LOT tougher without the #43.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
WOW...
Scott Burr in Ben Lomond CA
>Your box is in better condition than mine :^(
I think you'll like using it when you can!
