WE MOVED...
Tote for My Mitre Box Saw
Mike Fitterling
>I have a nice Miler's Falls Langdon Acme mitre box that a friend gave me, but the saw's tote was broken off at the bottom. I used it anyway, but broke the tote off the saw completely twice and had to repair the tote just to use the saw. I don't have a source of beech locally, so I was not going to be able to repair the old tote properly for a while, but I had a need for the saw.
So, when I was at Five Barns this summer, Dominic was cutting up logs and one was osage orange, of which he gave me a nice chunk. I was not sure what I was going to do with it, until I realized it would probably make a nice tote. (Rest of the chunk is in the background.) This was my first attempt at making a tote and really a utilitarian project more than fine woodworking, but I am happy with the way it turned out (I'm not pointing out all the mistakes I made ) and it was a fun project that only took a few hours. Finish is a quick spray coat of Zinssers amber shellac.
Cheers,
Mike
Re: Tote for My Mitre Box Saw
Utilitarian rather than fine woodworking?
Patrick Gibbons, Houston, TX
>The finest woodworking is utilitarian. (the sound you are hearing now is me ducking and covering from the incoming) I think it's great work. Rock on!
Nice handle
Bill Houghton, sunny Sebastopol, CA
>Nothing wrong with that one - I like the vigor of the two horns, top and bottom. I've got a saw with a handle from the sad decline era (1960s or newer) that shrieks "utilitarian" far more than yours.
Purty !
Steve Mackay
Marv
>Hi Mike,
Nice work on that handle....two hours?....I've made a few handles, don't think I could ever do one in two hours. Takes me that long just to do the rasping. You should apply for a handle making job with Mike W.
Marv
Osage orange, why!?! You should have used...
Scott Burr in Ben Lomond, CA
>Plastic!
Scott, ducking and running!
Nice looking handle.
Plastic trees not native to that part of U.S.
Hi Mike!
Dominic Greco in Richboro PA
>Mike,
You wrote:
"Dominic was cutting up logs and one was osage orange, of which he gave me a nice chunk. "
Wow, did you ever do that chunk of wood justice! I'm glad to see it went to such good use. That log was sitting in my wood pile for over 3 years. So I assume that by the time you got around to making the handle it was bone dry. It sure was tough on that chainsaw!
See ya around,
Dominic
>Mike
That is very nice work, very nice indeed!
Of course, like any gloat, it doesn't really exist until we see the shavings. In this case, the saw dust. Or, failing that, a little description of what you used to shape the tote.
Thanks All! More to Come . . .
Mike Fitterling
>The same friend who gave me the mitre box and saw called me Saturday morning and wanted to know if I would like a saw he had seen at a yard sale. He said it said "Disston" on it and had a little "bump" on the top (nib). I said yes and brought it home Saturday night. He paid four dollars for it, but would take nothing from me. :) Looking at it in the light of day on Sunday I realized the tote was a very old style, maybe the earliest, but did not in fact belong to the blade. It was held on by only the medallion and one screw because all the holes would not line up. I so far have not been able to find a etch anywhere on the saw, but it is filed crossctu and is 28" long. Tipes are sharp, but the bevels are pretty rusty; guess I have soemthing esle to lear to do. So I will save the old tote and break out the osage again. This time I will take some pics along the way.
Thanks again All for the compliments on my first attempt.
Mike Fitterling
>Next one, I will post pics, but this is how I went about making this one.
I took a big enough slice off the chunk of osage on the big bandsaw. Then I jointed one side flat on my Northfield. Ran that through my planer until I had the thickness right, comparing to the old tote as I went. I laid the old tote on top of the osage blank and simply traced the outline with a pencil, making up the missing bit at the bottom by simply guessing and trying to make it look nice.
Took the osage now to the little bandsaw with a 1/4" blade and cut out the outside shape. My jigsaw is broken, but my brother was coming over so he brought his and I cut the hole out with that (Guess I should have galooted it and pulled out my coping saw). Next I installed a 3/4" radius cutter in the router table and ran it only around the handgrip edges frontside and back.
Next I got out my various rasps, files, and a LN float and started smoothing everything out and making some of the details that a router cannot. The top and bottom edges were not radiused, but more arched, and I did that by hand with the rasps and float. Followed that work with a Dremel with a small drum to smooth out any bumps and get rid of any burn marks from the router bit. It was a bit of Dremel work, back to handwork, then Dremel work, handwork, etc. until everything was the way I wanted it.
Next, I had to make a mortise in the top front of the tote to accomodate the blade's top bar. I just penciled that in and chopped it out as I would a dovetail with a couple of my bench chisels. Then making a careful line down the middle and around the tote to the spot where on the original the blade left the tote, I made a cut along that line with the rip side of a ryoba. I realized after doing that, I should have made the kerf with the same blade of the mitre saw. So I switched and finished up the cut with that. I had to cut, test fit, cut, test fit until the blade would seat itself all the way in. I did not want to go too deep and end up cutting through into the open area of the tote.
Finally, I marked the holes for the screws through the old tote onto the new tote. I now realize that I should have marked them with the blade as the template instead, and it caused me some frustration getting all the holes to line up, one or another being off just a hair too much. I drilled the main holes with a striaght bit then put an auger bit in a brace and, with its lead screw in the hole I just made through the tote, I drilled the recesses for the medallion and screw heads.
Finally, I sanded everything first with 100 grit paper, then 220 grit. Took the tote outside, filled my touch up HVLP gun with amber shellac and sprayed it.
I was really surprised by the results and that it was not really difficult at all and the next one should be easier and turn out better. The other thing I was surprised at is how easily the osage worked. I thought it might be a killer, but I had no problem cutting or drilling, whether by hand or machine and it really took the finish nicely.
Cheers,
Mike
