OT - fastening glass in cabinet doors
Bill Houghton, sunny Sebastopol, CA
>Moving along on the kitchen...
We've ordered some fancy glass for our china cabinet doors; slightly irregular surfaces, bubbles, etc. The stained glass shop from which we're buying it, when they do an install, bed the glass down in 100% silicone, then run a bead of the silicone on the other side, like putty, smooth it out, and let it cure. No mention of glazier's points.
I've never had much luck with "smooth it out" with silicone, though I'm learning that, with most, mineral spirits help a lot, as does blue painter's tape to keep it corraled.
I'm considering wood stops, instead, with some thin sticky-back foam weatherstripping each side to prevent rattling. More work, since the stops would have to be cut, smoothed, drilled for nail/screw holes (ain't no way I'm driving nails or screws in the vicinity of $200 worth of glass without guiding holes), and painted, but maybe cleaner looking when you open the door.
Thoughts and experiences much appreciated from this knowledgeable community.
A side note: I was commenting to LOML on the way back from the glass shop about the irony that glass manufacturers spent centuries learning how to make smooth, bubble-free glass; and now it's the stuff with the defects that's more expensive and much sought after by people doing fancy kitchens. I suspect the same dimensions of glass in regular window glass would have cost about $30.
Re: OT - fastening glass in cabinet doors
>A rabbeted wood strip mitered around the back of the door and held in place with small brass screws is kind of an elegant alternative, although it is much more work. 100% silicone caulk is pretty easy to smooth out. I have never put a bead of caulk under the glass. The first few times it can be kind of messy but it is pretty simple to keep it clean. 1) Cut a very small hole in the tip of the tube, not a big hole. A 1/8" diameter hole is plenty big enough. 2) Set the glass in the door and spread the caulk in the corner of the rabbet by pushing the caulk gun, not pulling it. 3) Take your finger tip and drag it along the corner leaving a neatly filled corner. 4) Silicone caulk is fairly easy to remove after it dries by scraping with a razor knife.
ThomD
>My first hobby was stained glass, and most, if not all of the uneven glass I saw was actually flat on one side where they spread it out on receiving table. This could mean that one side, the back will actually be flat, allowing you to case it normally.
You do have the option of actually scribbing the glass in. So you would relieve the front molding a little, and when you scribed it in you would just work around slowly cutting it to the scribbed line, great job for a detail belt sander, though doubtless there is a hand tool alternative like violin planes, gouges etc...
Sometimes people make the front of the cabinet with molding inserted from the front since it's easier that shaping a larger piece of wood. If this was the case here it would be extra easy both in lay-out and work to pre-shape the molding before it was mitered and installed.
One of the trick of silicon work is to cut the end of the tube at an angle so that the caulking is released with pressure into the corner. You push the tube along and the tube itself forms the bead. do the top and bottom, let dry, and then do the side. That is probably the easiest method not to blow the corners.
Another option would be tinted epoxy with a stir stick as applicator. Tint the epoxy with dye powder or lighter coloured wood that will dry to the colour of the parent wood, or use a colour like blue. If you use sawdust, run it through the blender so that it comes out looking like flour. Mix one part cabosil with 3 part wood powder into a glue like WEST epoxy or Sytem 3. Add all you can short of it being so dried out the cove doesn't smooth over with a wet look. A popcycle stick (3/8" diameter) is all the cove you would need. mask the glass and wood outside of the target area.
I've used the foam tape...
John in NM
>I think you'd only need it on one side, and make sure to dry fit first, glass is not coming out easily with that stuff! What I had was white, so if you can't get a color similar to your finish it will be fairly noticable. I usually nail stops in, but with expensive glass I'd probably use screws - brass slotted screws of course!
"RJ" Whelan
>Bill ... I do a lot of glass doors and this is what works for me:
1. Line the rebate with foam tape (I use black) - leave the paper cover on for now
2. Make three "dummy" pieces of glass out of a wood scrap - about 1" wide by 2-3" long
3. Cut and mitre the moldings
4. Drill and counter-sink the molding for small screws (usually #4 x 5/8" for me)
5. Place the "dummys" in the corners and midway along one edge and set the molding in place and drill into the door rebate - repeat this on the remain three sides
6. Peal the paper from the foam tape and set the glass in place.
7. Install the moldings
Good luck .... rj
Andrew Lunn
>Hi Bill,
I've used a method like that described by Steve Latta in an article titled "Graceful Glass Doors" over at the FWW site. It might be just the ticket for you--it looks good and does the job well. Good luck.
Andrew
Oh well, you should have ask first...
Scott Burr in Ben Lomond CA
>I could have saved you some bucks maybe...
Sounds like you wanted anteak looking glass. My local glass supplier has a good supply of it. They keep old glass when doing window replacements in old houses like ours. They sell it for a lot less than any other place I've found.
Thanks, all
>Some very good ideas here, that will get mixed into my solution.
Scott - thanks, though we're talking seriously funky glass here, looks like it was made by a five year old, and I doubt that LOML would have wanted less. She's the accountant, and she says it's in the budget, so I respond with "I'll just put that right in the cabinet doors."
OT - kitchen cabinet results
>Thanks to the good advice of this group, I've got some pretty china cabinet doors now.
Detail
>This is the best corner of the wood stops. I couldn't afford the slotted brass screws, but the phillips don't look bad - and besides, Phillips is a family name on my mom's side, so I can think of it as honoring that part of the family.
Re: Detail
Jim Shaver - Oakville, Ontario
>Nice Work Bill,
I can see that this was well worth the work you put into it.
Thanks for posting your work, I like seeing what we make here as much as what we make things with!
Take care,
Jim
Re: Detail
Brad in Ottawa
>Great work Bill! I just have to hide this from my wife. I just finished redoing my porch this year as a homage to you! There is no way that I am redoing any cabinets though!
Re: OT - kitchen cabinet results
Wiley Horne
>Bill,
The cabinets do a wonderful job with the light which plays on them. I especially like the way the light falls on the shelf edges. Am sure it gives the entire kitchen a larger, more open, and airy look.
Congratulations!
Wiley
I see what you mean about the glass now...
>Very interesting visual affect. They turned out nice Bill!
You should have seen me carrying it around
>I had to store it upstairs in the tankhouse, above my shop, and when I carried it down, and then individual panes out to the shop to fit in the doors, and the doors in, I kept thinking, "Each of these little puppies is $100 worth of glass." VERY careful walking.
