THE WOODRAT IS BACK!
Portable tail vise?
Portable tail vise?
Portable tail vise?
Norman (Ottawa, Ont.)
>I've taken a few days to rediscover my inventive self, had some fun doing this along with some frustration. It has worked out in the end, it's mostly all there, it works amazingly well..
Photo below of V3 of the prototype, components are made of beech and cherry. You can see the original Version 1 threaded bar and handle assembly in the background along with another clip on jaw face.
A locking knob can be seen below the 2nd dog, this dog slides into the next to first available dog hole..
Something I always longed for is a removable and portable tail vise. I could quickly set up a temporary bench, drill a few co-linear 3/4 inch dog holes and have the capability to hand plane any size board within the confines of the bench of course.
Having determined the criteria I needed and strived for, I've come up with a design. I thought I would run it through the hand tool crowd here to determine if this is something worthwhile pursuing.
There is a quick, coarse adjustment which involves loosening a knob 2 turns and sliding the shaft forwards or backwards. Once the top knob is locked down, the shaft is engaged and it can be torqued against the board to be planed. The front jaw is quickly detachable and has a racking provision in it to withstand any diagonal hand-planing. There is no vertical racking as the forward , 2nd variable dog part is locked into the bench. The coarse and fine adjustment mechanism is contained in the 1st dog block. The top locking knob automatically detaches the mechanism from the threaded shaft.
Top knob can easily be interchanged with a cam clamp if desired.
My criteria is as follows:
Criteria and requirements of the portable, removable tail vise design
1. Completely, quickly and easily detachable from workbench.
2. No extra provisions in bench to mount the tail vise aside from bench dog holes.
3. Ability to withstand vertical racking
4. Ability to withstand horizontal racking, both diagonal and perpendicular to bench front
5. Provisions for low-profile hand planing
6. Adaptable to any corner of a work bench where round bench dog holes are located
7. Versatile regardless of workbench hole spacing
8. Assembled with off-the-shelf hardware
9. Easily replaceable components
10. Has a small footprint
11. Works in conjunction with round � inch diameter bench dogs
12. No need for any tools to install tail vise to workbench
13. Versatility for left-hand or right-hand installation to workbench
14. Rapid, initial coarse adjustment feature
15. Fine adjustment to torque jaw to board to be planed
16. Quickly detachable and replaceable jaw, no need for tools
Thx for looking,
Norman
Re: Portable tail vise?
>Hi Norman
Great work. Similar to but improved on the Veritas version (which I use). I shall be making one of yours.
Here is a larger image to make it easier to see details:
Veritas version???
Denis Ch�nard, Orl�ans, Ont.
I want one of these!
>Great idea!
Here I am with my old plywood top bench, without a tail vise... I built that bench years ago because, well, you're supposed to have one if you're a woodworker...
Back then I wasn't using hand tools at all, but now that I use them quite a bit I've been missing on a tail vise. I thought about getting the Veritas Twin-screw vise, but it's kind of pointless to install that on my old bench, I'd rather make a new "real" bench, but time taken to make such bench would be taken from other chores around the house (of which there are plenty, my wife reminds me...).
Your invention would give me a tail vise capability that I wouldn't be able to get otherwise... Love it!
So, where do I get in line to buy one? I want a signed copy, of course :-)
DC
Re: Veritas version??? *LINK*
>Hi Denis
I am surprised that you do not know - or have just forgotten - what are you drinking tonight!!? :)
Veritas have designed and market the "wonder Dog" and the "wonder Pup"
I use the latter in my bench when I need a tail vise (I generally just use a planing stop for most work).
Link below.
Veritas Wonder Pup
>Never thought of the Wonder Dog as a tail vise, but now that you mention it I guess it could do in a pinch, yet I'd rather have Norman's device for that purpose.
DC
BTW I drink Lindeman's Bin 65 tonight, in moderation of course... :-)
