Tool Gloat/Tuning Questions
Ken Bellock (Houston, TX)
>I just received my new set of chisels! I have another small set of paring chisels, but I have wanted these for quite a while now. Now that I have them, it's time to get busy tuning them up. I learned a lot tuning up my last set, and am planning on using the same system for these, but I would like to get a few opinions before I start. Especially with as many hours as I see going into this. So far I have just removed the grease that was on the steel for shipping, and put a light coat of boeshield on them.
The plan is to use glue backed sand paper on marble tiles. I will work my way through the following grits: 100, 120, 150, 180, 220, 320, 400, 1000, 2000, 4000, then finally .5 micron. The technique I used on my last chisels was to sand diagonally with one grit, then switch to the other diagonal on the next grit, so that I am sanding perpendicular to the last grits scratch pattern, and then to sand until all the last grit's scratches are gone. Last time I sanded dry, using compressed air to clear the metal shavings from the paper as I worked. The sand paper didn't seem to last very long before losing it's bite, and I would go through several strips for each chisel on each grit.
I start tomorrow night, so any comments or suggestions would be greatly appreciated.
Re: Tool Gloat/Tuning Questions
Jack Guzman from Maine
>Wow! You sure have your work cut out for you. 9 chisels,11 steps each that's 99 separate steps. How bad are these new chisels? When I got my Two Cherries all they needed was honing,which consisted of a few passes on a 1000 grit water stone followed by polishing with a 4000. I tried scary sharp when I first started out but I found it too fussy so I switched to water stones. So much quicker.Of course,I hate sharpening. You may enjoy all that setup.Have fun with it.---Jack
Pedder
>are you sure that it is necessary to start with 100? Would take a test with 1000 to see how flat they are. Before starting with 100 i would send them back.
cheers Pedder
>Technically I don't believe there is any benefit to polishing the back past 1000 grit. There is a point where you get zero return for the time spent. A nice set of chisels.
Ken, that is not necessary.
Two goals only are required:
(1) The back of the chisel must be flat. It does not really matter to what grit. I would be very happy with 400.
(2) It is important that the area immediately behind the bevel face edge is flat and as smooth as the bevel face. So if you plan to hone the chisel to .5 microns (Veritas green rouge), then that area must be dealt with likewise. I would aim for 1" behind the bevel.
Test the flatness and smoothness first before bringing out the big guns.
If - and only if - the steel is out, depending on how much steel is to be removed, go to the lowest grit that can be used safely (i.e. does not create deep scratches that require a lot of resanding).
You can jump a lot of grits. I usually "double up", such as 120 -240 - 400 - waterstones (1000 - 5000 - 8000).
Pam Niedermayer - Austin, TX
I think it's important to always issue a caveat when making the above statement since many of us think it's important that the entire back be flat unless it's a special curved back slick/paring chisel, in which case the curve is there to protect one's hand. And while we're at it, many of use don't care much for microbevels, back bevels, and the like either. I do care for back hollows. :)
Pam
>Thanks for all the comments. I'll definitely try a higher grit first, that will save the most steps if it works out. There are pretty deep milling marks, and a single deep depression, like a pin hole, towards the front of each chisel on the flat side. (Hardness test?) I like the entire back side of the chisel to be taken to the same grit as the last inch. Just a personal preference. I know it's a lot more work, but it's worth it to me.
I'll take pictures as I progress for my own notebook. If anyone is interested, I can post a few later and provide an update on how it went.
Thanks again everyone!
