Veritas - Innovation in Tools
Some restored hand planes
Dominic Greco in Richboro PA
>Hi Everyone,
I finally finished restoring a bunch of handplanes and decided it was time to post some pictures.
The first one is a Union No7. Here is a "before" picture.
Union No7 Jointer Plane - BEFORE
The body was bead blasted and Re-Japaned with high solids black paint. The original lever cap was missing so I bought a new one from Stanley. The blade and chip breaker had some pitting due to rust and were retired. A new LV blade and Stanley Chip Breaker were added. The tote and knob were stripped, cleaned, re-stained with rosewood stain, and given several coats of wipe on Poly. The sole was flattened and polished to the mirror finish you see now.
The second one is a Wooden Union Warranted Jack Plane with a Butcher Iron.
Photo Sharing and Video Hosting at Photobucket
I got this for $5 at a yard sale. I cleaned and sharpened the iron, stripped and cleaned the body, and made a new tote out of cherry. I still need to fine tune the wedge since I have been told that this is the most likely cuplrit for chips clogging in the mouth area.
The English Stanley Bailey 5C looked a lot worse than it really was when I got it.
The sole was in nice shape when I bought it. All it needed was to be cleaned and fettled a bit. I was also informed that since this was a "newer" Stanley that it would not be fit for anything other than tossing at an unruly relative! After tuning it up and putting newly sharpened blade in, I'll have to say that I disagree. It's actually quite nice to use and produces whisper thin shavings. I can tell that this will become one of my "users".
The No4 was one of my original hand planes and was purchased at a yard sale for $10. I don't have a before picture of this one or the Defiant No3 that I purchased from a former co-worker. Both planes were cleaned, had their soles flattened, chip breakers turned up, and blades sharpened.
Restored Handplanes
Restored Handplanes
Restored Handplanes
Restored Handplanes
Just to give these planes a work out, I decided to flatten a 6" wide piece rough sawn 4/4 cherry. I was very impressed with the way that the No7 and No 5 handled. The No4 smoother worked quite well, but the Defiant No3 needs some tweaking. I think it was due to the frog being set for too fine of cut. When I backed off the blade it was able to take really super thin cuts.
That's about it. I have several other planes waiting in the wings to be restored. But they may have to wait a while. I'm bushed! :>)
See ya around,
My ugly mug
Dominic
Re: Some restored hand planes
Hey Dom, Nice work. Thanks for sharing.
VLParisian
Jack Guzman from Maine
>Nice work Dom. I guess this means you're not just passing through here on the hand tool side.Hand planes are a lot of fun to refurbish.---Jack
Jim in Burlington Ont.
Very nice
>Should live on for another 100 years.
nicely done! and a ?
Tom Sontag - St. Louis
>Mighty fine rehab Dom. Those bottoms look just a little too perfect though; you got access to some super flattening equipment? What did you use to polish those soles?
Re: nicely done! and a ?
>Hi Tom,
Thanks for the compliment! All I used was a piece of 1/2" thick glass with assorted grits of wet dry sandpaper adheared to it. I start with 60 grit, then 120, 220, 440, 600, and 800. Then I move to 1500 and then 2000 if I REALLY want to shine it up.
Later,
Dominic
Jim Shaver - Oakville, Ontario
>Great results Dom......they look like a set of real users...
Take care,
Jim
Dave Anderson NH
>Well Done Dom!! I'm assuming that this means that you'll be backing off on the turning a bit and doing a bit of flatwork too?
Best regards,
Dave
wilbur
>Very nice job! I wish my Stanley planes looked that good.
