Hamler Scraper insert
Terry in Denver
>Has anyone seen an update on the Hamler scraper insert (that can retrofit into a Stanley #7)? When it might be available? That's one item I would really like to add to my arsenal.
Thanks,
Terry
Terry in Denver
Thanks,
Terry
Re: Hamler Scraper insert *LINK*
dave brown
>You can email Paul to have your name added to "the list."
You can check out his blog for more info on him & his projects.
Hamler Tools blog
Terry in Denver
>Thanks, Dave.
Terry
Walt Q
>I had a long talk with Paul a few weeks back at the LFOD auction, mostly about scrapers and scraper blades (consensus: thinner is better, you always want some flex)...the inserts are still a few weeks off but coming up maybe before Halloween....had a chance to play with the new design and I gotta say...It certainly is a winner...solid as a rock and the adjustments are spot on...I especially like the use of the spring instead of the inner capture nut, don't know why someone at Stanley didn't think of that modification. I'm thinking of modifying some of my scrapers to use the spring. The one he had on display was the Bedrock design and installed in a Bedrock #7. I'll drop mine (regular model)into a garden variety 7 and/or 6. Will report back on my observations. It will ship with a blade but there's no stopping you from making your own. Can't say how many saws I've carved up over the years...best ones to use: Atkins silver steel, they make perfect scraper blades.
I do have somewhat of a scraper fetish...
also had a chance to see some more of his miniature work...the small router is a BLAST!!! a lot prettier than the lowly Stanley #271 and easier to use....sweet!
Walt Q
springs
dave brown
>Hi Walt,
When you update your scrapers w/ springs could you let us know where your source your springs? I emailed Paul but I imagine he's a little too busy to email a reply about springs. ;-)
Dave
Re: springs
Walt Q
>Dave,
Paul's recommendation was any stock spring that wasn't too heavy...not a lot to go on but I figure I'll bring one of my 12's with me (dismantled)and do a quick assembly to see what works best...I have a store near me ...the nutty company which has a wide variety of springs...hopefully they'll have something that will work..
walt Q
Springs you say... *LINK*
Scott Burr in Ben Lomond CA
>Lee spring has a nice calulator, just follow the type of spring you want.
Here's another supplier that are stocked at most hardware stores:
http://www.centuryspring.com/
Lee Springs
Re: springs
wayne anderson
>I liked the idea too, so added this spring that I had on hand. Tried a smaller (weaker) one, and it didn't work out. Also added a little brass washer. The assembly works quite well now. Seems odd that someone didn't come up with this before. -wayne
thx
dave brown
>Awesome guys, thanks for the suggestions.
I like the look of your 212 in iron, Wayne. Mine is brass & cherry and I don't think it's as attractive as the iron & (is that cocobolo?)
Dave
Re: springs
Pam Niedermayer - Austin, TX
>That's an amazingly attractive plane, Wayne. Looks like it functions like a champ, too.
Pam
Re: springs
Terry in Denver
>That is a nice look. For some reason I get thirsty when I look at that picture!
Terry
Re: thx
wayne anderson
>"...(is that cocobolo?)
Dave"
It's whatever kind of rosewood that L-N uses. -w
spring length?
dave brown
>Is that little spring pretty stiff? What do you think the uncompressed length is?
I like the brass washer.
regards,
Dave
