Veritas - Innovation in Tools
Drying thick Walnut Planks?
Paul in NJ
>I have some 4/4, 5/4, 8/4 and 12/4 walnut that has been drying outside for a year. The 4/4 and 5/4 is down to 11.5-12 percent according to my moisture meter and I have moved that into my shop for use later this year. I doubt the thick planks are that dry on the inside. Should I leave the 8/4 and 12/4 outside for another year or two? Do you think they would dry quicker inside the shop? I keep a little heat in the shop all winter and run a dehumidifer during the warm humid weather. I also keep a small fan running all the time to keep the air circulating.
Thanks,
Paul Dzioba
Re: Drying thick Walnut Planks?
>Air drying hardwood takes about one year for every inch of thickness. This also depends on seasonal and weather conditions, temperature and humidity, air circulation, phase of the moon, &c.
Sounds like you are doing everything right. Just be patient, air dried wood behaves much better than kiln dried wood, from working, gluing and finishing.
Stephen
Michael Stadulis, in Gloucester County, NJ
>Hi Paul,
I moved my 10/4 walnut into an unheated basement after 4 months and it did fine. Walnut is a well behaved wood. Sounds like you did well.
-Mike in Gloucester Co, NJ
"RJ" Whelan
>Paul ... I'd leave the 8/4 outside until spring and I'd give the 12/4 another year outside. I think the key is to avoid large changes in ambient conditions ... rj
