Metallic dryers
Metallic dryers
Metallic dryers
John Hoffman
>Hi guys, I am using Boiled linseed oil with metallic dryers. I know Bob Flexner wrote an article in PWW on the safety of this product after it drys. The question I have is, does this product cause any problems when inhaling the fumes during use?
Thanks
JH
Re: Metallic dryers
Jim in Burlington Ont.
VOC
>I'd be more concerned from the VOC if your product has been thinned than metallic dryers.
Re: Metallic dryers
Re: VOC
Robin Corell in Atascadero, CA
>turp is also a dryer. Most use it ony to thin but it also has drying properties.
Robin
Re: Metallic dryers
Re: VOC
John Hoffman
>No, I am wiping the boiled oil on and not spraying and not thinning it with any solvent. I guess it is pretty safe. I hope...
Re: Metallic dryers
Re: VOC
John Hoffman
>Could terp be mixed with raw linseed oil to make it dry?
Re: Metallic dryers
I use Tried and True
>I think it's very safe. You can google MSDS for your particular product and see what it has to say. Ususally the love of your life will let you know if it really stinks and perhaps you should be using something else:)
http://www.setonresourcecenter.com/msds/docs/wcd00025/wcd025c0.htm
Re: Metallic dryers
Re: I use Tried and True
John Hoffman
>Jim, without trying to stir a hornets nest, have you had problems with Tried and True? I was told that you wipe it on and after an hour wipe it off and you are able to get a build this way, and I have been told to stay away from it because it doesn't dry. What has been your experience with this product? I have not used it and please email me off line if that would be more appropriate.
Thanks
John Hoffman
johnah5@yahoo.com
Re: Metallic dryers
yes, it is slower to dry
VTAndy4
>but at least you can feel good about the reason why. I finished our coffee table with it and was able to move it into our living room, where our one-year-old plays, within the day. There was a nice beeswax smell. I'd say that it took a few days to feel dry and about one month to fully cure. (This was the beeswax/oil mix.)
Re: Metallic dryers
Alot of rubbing
>I put my can in a bigger can and pour boiling water around it for 15 minutes first. Then I don't just brush it on like thin oil's I really rub it in. Old used blue jean's work the best IMO. It's like 30 weight oil in the winter. Makes your arms tired but the sheen to my eye is fantastic. Takes a good 3 weeks for it to dry up nice after 3 coats.
Re: Metallic dryers
Re: A lot of rubbing
VTAndy4
>That was my experience also, in the winter. Instead of warming in water (which does sound like a good approach), I moved the project into the house. I only did two coats but plan to rub in a few more coats within the first year. I think that it is a beautiful looking finish.
-Andy
Re: Metallic dryers
Tom Colligan
>I recently heard Sam Maloof say he finishes his furniture with a robust rub down with a rag. (He may have been referring to an old tee shirt or a towel.) "You'll be very surprised as it's like 2000 grit sandpaper. A very noticeable improvement." His words, more or less paraphrased.
