THE WOODRAT IS BACK!
Warren carving tools
>My wife's sister died a few years back and Meg has stitched a sampler (not sure if this is the correct term but I think you will understand what it is) for her parents, and I usually volunteer to make the frames for her stitching. Meg usually does not mind waiting a year or so, and in fact her stitching is currently about 1.2 lifetimes ahead of my frames. Her sister collected a number of Celtic things and I have since read about such things and find Celtic art interesting. So the walnut picture frame will have an arch at the top with a simple triangular celtic knot cut in relief in the frame with the back ground lowered around the whole frame with a small bead around the inside and outside of the frame. I'll use a gouge to lower the center of the frame across grain so it will have a pretty noticeable texture on the background I think. This will be put on display at the local county fair. Of course since I only have one small carving gouge I had to get tools to do this. Looking through the LV catalog I noticed they had a large Warren carving tool set which looked like it was sufficient to tackle the carving I want to do so it will probably be here on Tuesday. Since this is some of the first carving I will attempt it should be an interesting and challenging project plus I get new toys out of the deal. Hard to beat. Last night I sharpened up the new iron I made for my scrub plane and tried it out and now I am hyped about finding a good piece of walnut out of my stash and smoothing it entirely by hand for this picture frame project. Plus I am losing sleep over the carving tool deal; I suppose if LV has them in their catalog they are worth spending the money.
Re: Warren carving tools
Warren in Lancaster, PA
>This post caught my eye for some reason. I think I would have suggested individual carving tools for this project. Usually in carving a knot you only need two gouges, one to delineate an inside curve and one of slightly larger radius for the outside of the curve. The rest you can do with bench chisels. Also for walnut I would strike the gouge to define the curve- not sure this set is made to be struck with a mallet. I think you can do the work with the set ordered, but it is easiest to carve when you have just the right radius.
One suggestion for the carving is that it need not be very deep to be effective. 1/16" might be enough depending on the size. The deeper you go the more difficult it is to dig out the background in a nice clean and uniform manner.
Pam Niedermayer - Austin, TX
I would say that items in the LV catalog are good for someone doing some task. Or, generally even the plastic trinkets are useful to someone. However, whether they're good for you and your task you'll find out soon. I'm a little bothered that there are no sizes in the description.
Sounds like a nice project.
Pam
