Cutting up cracked wood
Jeremy Osner
>Does anyone have good advice about cutting up some lumber with large cracks in it, to maximize the amount of usable wood? I have several boards that are coming apart at the ends. Is my best course: to crosscut the boards before the cracks begin, and then rip? I would lose a fair amount of length this way. Or, to rip along lines that avoid the cracks, and toss the pieces I was not able to get inside the lines? I would lose some good wood this way too, since some of the cracks are 45 degree angles across 6/4 thick wood. Or some combination?
Here are pictures of a bench I built out of some of this wood. This might be the best way to go -- just cutting curves around where the cracks are. But I have not done a lot of curved work in the past and I have some good ideas that involve square, straight boards. (The bench is white oak, built with all hand tools plus a bandsaw and a power drill, but most of the work was surfacing with planes and shaping with spokeshaves, joined with dowels -- hence the drill -- and finished with Watco teak oil. It took about 4 or 5 hours of work, but spread out over a week or so. It is pretty comfortable to sit on.)
