Hey Kevin, what;s going on with the squirels?
Scott Burr in Ben Lomond, CA
>Has anybody won the pool? Have they beaten the wheel?
Inquiry minds...
Inquiry minds...
Re: Hey Kevin, what;s going on with the squirels?
Kevin French, Antrim, NH
>The Rats are jumping onto the wire from the other end. My next plan is to cut an metal electrical conduit into 2 or 3" segments, maybe with a fender washer between each segment and string them on the line for about 5-6' each side of the feeders.
Ernie Miller
>Don/t waist you time. there is no real method of stopping tree rats. if you want to feed small birds put the feeder in a cage that the squirls can't get into but the easiest way it to spike you seed with Cianne pepper it will burn the tong of the squirls sinse birds have no tong it will not bother them. just do it for a short while and then you can quit they will know to stay away. if they forget after a while do it again. simple effective. I don't have tree rats at my feeder but do have lots of birds.
Re: Thanks Ernie
>I forgot abot the Cianne pepper, I'll have to get some. I'm still going to do the conduit thing. Every good Cbt Engrs know that obstacles are best employed in series and in depth.
Swmbo says it's my own version of 'Caddy Shack'.
Marv
>Kevin,
Put your feeder at the top of a metal pole, about 8 feet up. Nothing can climb up a metal pole.
Marv
>Except we have another friend who fond of seed, Ursus Americanus, The Black Bear, who won't climb the pole but, WILL knock the pole over.
Re: Thanks Ernie
Ernie Miller
>I can see that! Ok you know them pull string popers can you employ some of the? even just snaps might be fun
Re: Thanks Ernie
>Enrie I was a Cbt Engr in the Army, I have Anti-Handling Devices for the M15 Tank Mines. These I can be reloaded and kept the deer out of my garden one summer so if the conduit doesn't work that maybe the next step.
