Steel rant
Steel rant
Steel rant
Denis Ch�nard, Orl�ans, Ont.
>I've been toying with designing tools of late, and I use mild steel (mostly bar stock so far) for my crazy ideas. My problem is that mild steel comes with radiused edges, and for a number of applications I would prefer straight square edges. But it seems that the only way for me to get steel stock with square edges is to buy tool steel. I bought a length of 01 stock at Metal Supermarkets, and it came back at $60 for a 36" long 2" wide 1/4" thick bar... A bit rich to make experiments, especially since I don't need tool steel for many of the parts.
Is mild steel bar stock with square edges available, and where can I get it?
TIA,
DC
Re: Steel rant
try hot rolled
Robin Corell in Atascadero, CA
Re: Steel rant
sorry ment cold rolled
>was thinking your problem is that you have been usung hot rolled. cold rolled is run through a second set of forming dies and it produces a smoth surface with crisp corners.
Re: Steel rant
http://www.buau.com.au/english/b_2596.htm *LINK*
Andrew F in Australia
>Try looking for your local equivalent to this, Denis.
Cheers,
Andrew
Re: Steel rant
Re: Steel rant
Norman (Ottawa, Ont.)
>Denis,
I have some lengths of 3/4 or 1 inch. cold-rolled round steel bar here I haven't used in 4 yrs.
I bought it then when I had the "crazy" idea to put together my own CNC router system, and these bars were to support the X-Y axis gantry system. I came to my senses a short while later :)
I don't need it anymore.
Norman
Re: Steel rant
Re: Steel rant
Marv
>Hi Denis,
Tool steel is ground to dimension, that's how the sharp edges are made. Cold roll is formed with square edges but not ground. The reason the tool steel is so expensive is because grinding is a slow process and of course it is hardened and is a higher grade of steel. It can also be hardened as you probably already know.
Do you have a belt sander? If so you can sand two sides to get the sharp edges on cold roll. If the parts are short, it's fairly easy to do. Hot roll is out of the question for your application. Hot roll is horrible stuff to work with. But it has it's place.
Marv
Re: Steel rant
Re: Steel rant
>Norm, I might just have to pay you a visit :-)
I'll get back to you offline later today (got to clean the house before visitors arrive...)
DC
Re: Steel rant
Jim in Burlington Ont.
Small bit's
>Denis if you only need small bit's try a machine shop. They usually have a bunch of small bit's around in their scrap bin. Steel's really shot up in price lately. Some of those replacement HSS blades that LV sells are a really good deal.
Re: Steel rant
Re: Steel rant
Sandor in Middletown, DE
>Try www.onlinemetals.com for your cold rolled steel. They show a 60" 1/4 x 2" 1018 (mild steel) bar at US$16.20
Shipping is reasonable and estimated as you place items in your cart. While there you can get all the metals you need for that infill project you know you want to start!
No connection, just a satisfied customer.
Sandor
