Respecting the disrespected
>The little saw pictured below was a gift from one of the folks who painted my parents' house before sale to my brother, in thanks for the radio we gave him; my bro, in turn, passed it on to me.
At the time, I thought, "oh, great, another junky little saw." I also thought, "gawd what an ugly handle." But: it's turned out to be surprisingly useful as a remodel saw, because it fits into small spaces, and the blade's better than I expected. I continue to think the handle's ugly, and uncomfortable too - if/when I get to it, I might make a better handle - but it's definitely a keeper.
I sometimes fall into the trap of thinking that I have to have tools I can't afford in order to do the work I'd like to do. This thought is a variation of the issue Bill Tindall raised in his "philosophical" thread below. While there is a certain minimum level of quality necessary for a tool to function, I'm slowly learning that, once that level is reached, quite a bit can be done with a junk tool.
Will I stop looking for high quality tools (in my case good rust)? Heck, no. But I think I'm learning to do with what I have.
Re: Respecting the disrespected
VLParisian
>Bill, That is one ugly saw. Glad to hear it worked for you.
Victor
Marv
>Hi Bill,
Your little old ugly saw is a Plumber's Saw. That's the name Disston and other saw makers gave it. It was sometimes made to include other blades such as a compass blade and a keyhole blade. When there were several blades they called it Plumber's Nest of Saws. The larger blade like you have had small rip type teeth that was meant for cutting nails. Simonds made plumber's saws from 12" up to 26" blades.
You might try just radiusing the edges of the handle in order to make it more comfortable to use. Then paint it a nice John Deere green.
Marv
Paul M. in San Diego
>Another possible modification would be to retooth it so that it cuts on the pull stroke. Those narrow bladed saws are hard to use on a push stroke as there isn't a lot of steel to prevent kinking.
Marv
>The teeth can be filed to cut on the pull stroke by merely filing them opposite from the normal way of sharpening. In other words, instead of filing from right to left starting with the handle to the right, you file from right to left starting with the handle on the left.
Even the larger saw blades will buckle and bend if not used properly and kept sharp, same with a smaller blade. With that in mind, no need to file the teeth to cut on the pull stroke, but it's not a bad idea though.
Marv
Now why didn't I think of that???
Marv
