Question???
Question???
Question???
Marv
>Sometimes it's rewarding to get an answer to a question that I used to know the answer to. Or I just think I knew.
Here's the question....what is it called when you extend the tenon through the other end of a mortise and drive a peg through it?
Thanks in advance,
Marv
PS....OT....A 40 kilobyte image will not upload into a message. The file size has to be less than 40 kilobytes. 39.9 works but 40 doesn't.
Re: Question???
Re: Question???
Pam Niedermayer - Austin, TX
>Do you mean when the tenon extends through a mortise that breaks the board on both sides? If so, it would be a wedged through tenon/mortise.
Pam
Re: Question???
Tusk tenon?
Denis Ch�nard, Orl�ans, Ont.
Re: Question???
Re: Question???
wilbur
>There are a number of ways of putting a piece of wood through a tenon to lock it in place. "Handwork in Wood", by William Noyes, is a book available at gutenberg.org that illustrates a number of ways to do this. The section on mortise and tenon joints ought to have a picture that matches what you have in mind.
Re: Question???
Dale Lenz
Re: Pinned tenon
Dale Lenz
Re: Question???
Yeah, could be, depends on what wedge is used.
Re: Question???
Dale Lenz
Re: Tusk tenon is correct *LINK*
Dale Lenz
>Could not visualize what the poster was talking about earlier today.
Wedged Tusk Tenon
Re: Question???
Re: Question???
>If it is pegged through the mortice and tenon it is a pegged mortice and tenon joint. If there are wedges endgrain in the tenon it is a wedged mortice and tenon joint. If the peg or wedge is exposed and passes only through the tenon on the outside of the mortice it is a tusk tenon joint.
Stephen
Re: Question???
Re: Thank you...all
Marv
>Hi Stephen,
Thank you for putting it perspective. It's the "tusk tenon joint" that I was trying to explain in my question.
Marv
Re: Question???
Re: Thank you...all
Peter Hyde
>Sorry to be different but this is a tusk tenon. Notice the wedge direction and also the extra dadoes. Used as a structural joint in the joists around openings in floors. Also take note of the ratios in relationship to the joist sizes. The tusk is the protrusion under the tenon and resembles the relationship between an elephants tusk and trunk, the trunk being the tenon.
Re: Question???
Sorry to differ
>It is also called a Keyed Mortice and Tenon joint.
Stephen
Re: Question???
Re: Thank you...all
Marv
>Thank you Peter,
Thank gawd for steel galvanized brackets for attaching joists....
Marv
Re: Question???
Exacty what I was thinking of...
Marv
>Thank you Stephen,
Your diagram shows exactly what I was thinking of when I posed the question.
Marv
