Need a sanding trick . . .PLEASE !
SteveM
>Striped the paint, just sanding now. I've been useing an assortment of blocks and dowels wraped with sandpaper to get the rest of the gunk off. But I've got a couple small ( 1/4" - 1/8 " )beads / grooves around the turned legs I'm trying to get into. I've seen this round " Jeweler's " emery tape but it looks like I'd have to order it. Might there be any handy, in house options ? I'm usually good at improv but at a lose on this one. Its probably stareing me in the face !
Re: Need a sanding trick . . .PLEASE !
MikeW
>Hi Steve,
I've made small sanding blocks using a carving gouge, the reverse of the beads/detail and spray mounted sandpaper. If you have a Rockler nearby, they have rubber profile sanding blocks already made--which is what I purchased last time when faced with this inglorious task.
Take care, Mike
get some cloth backed paper, then floss
Ed Snow
Pocketknife
jim reed @ tallahassee
>Pocketknife can be handy for getting into the sharp "V" of turnings. Just run the knife around and score the V. Works well at the base of beads and can be surprisingly fast at flaking off finish. Good luck.
>Whenever I strip paint I brush on a heavy layer of stripper and let it set for a little while then remove whatever I can with a putty knife. At this point I assess whether it needs another coat of stripper to get the paint or finish off. A shellac or laquer finish does not normally need more stripper, but several coats of oil based paint will need two coats of stripper. If it needs another coat of stripper I put on another heavy coat and let it set then remove what I can with a putty knife. If there are areas left where the paint wasn't lifted I just hit thos areas again. At this point I take a pad of coarse steel wool and chemical resistant gloves and put some of the stripper on the steel woold and scrub the whole piece. It is at this point, with the steel wool, that I try to remove everything from the crevasses as well. Tight areas may need several spot doses of stripper to remove all the paint. The trick is to remove all of the old finish without marring the wood. After all the paint or finish is removed I go over the whole piece with a rag soaked with whatever is recommended for removing the stripper; either laquer thinnner or water. I use a medium steel wool soaked in the water or laquer thinner to remove all the stripper from the crevasses. At this point with all of the finish and stripper removed the piece should need only a light sanding before refinishing.
Ya need to make yourself 2...
Scott Burr in Ben Lomond CA
>Scratch stocks. Get a old hack saw blade, grind the profile, apply stripper and scrape away!
