Anyone ever tried this?
Denis Ch�nard, Orl�ans, Ont.
>Using a standard bench plane (bevel down, 45 degree frog) on difficult grain lumber, tearout ensues. Given that the blades are commonly sharpened at 25 degrees, has anyone tried to just flip the blade over, giving a 70 degree angle of attack? David Charlesworth reportedly grinds back bevels to get to that kind of effective angle, and I assume the back bevel makes for a stronger edge. I'm just wondering if the edge can take it without modifications...
Never tried it myself, just wondering if anyone has...
DC
Side question, are there terms used for effective angles beyond half pitch (60 degrees)?
Re: Anyone ever tried this?
Chris Scholz
Chris Scholz
>Depends what you mean by 'standard bench plane'. This practice is standard procedure for standard Chinese bench planes since at least a few hundred years. They also use the wedge behind the blade on occasions.
Are you talking to me?
>Naaa, wrong name :-)
DeNis
LOL! Just pulling your leg...
>I should have paid more attention when you posted that, for some reason I assumed that you had ground a 45 degree back bevel...
DC
Re: LOL! Just pulling your leg...
Paul Kierstead
>He did grind a 45 degree back bevel; His primary bevel is 90 degrees.
Paul Kierstead
>Doh. Never mind.
