Ohio Tools #2 blade adjustment knob.
Robert Henderson
>I was given a cute little bench plane that is about the size of a Stanley #2. it has a tapered iron and people tell me that that indicates an Ohio Tools plane.
It doesn't have the knob to adjust the blade depth. The previous owner had jammed an oversized hex nut on the screw.
It is a left-hand thread and a knob from my Stanley #3 will work - although I have to remove the tote to get it on.
Does anybody know of a source for a replacement?
Highland Hardware sells one in a set with all the other screws, washers, etc. that a plane would need. The $26 price tag is a bit steep for the one knob that I need.
Re: Ohio Tools #2 blade adjustment knob.
Neal in San Jose
>Robert: First of all, you have a fairly scarce and collectable plane on your hands. One in pretty good, but not mint condition sold about 2 weeks ago on ebay for $340. I've seen pristine examples go for several times that amount. You will want to seriously consider any modifications that may impact the value. I don't think that replacing a missing blade adjuster knob with an incorrect one will matter much, but the normal knocks and dings that using it invariably bring, will.
Second, a number 2 for most people is of marginal use. They are cute, but too small for most hands. A number 3 or 4 would quite likely be a more useful choice, and you wouldn't constantly worry that it was going to land on the floor with a very expensive crunch!
Third, there are people who sell parts for obsolete planes (Ohio Tool went out of business in 1916), but $26 for a knob doesn't sound too bad. You might consider going on ebay or to an old tool swap meet and finding a much more common #5 in ratty condition for about $25, and stealing the parts you need and selling the remaining parts for whatever the market will bear.
If it was me, I think I would try and peddle the cute little thing to a collector, and pick up a dirt-common Stanley #4 as my user, and have some cash left over for wood.
HTH Neal. remove an "o" for email
Clint Jones
>The ohio No.02 that sold on ebay was corrugated that is why it brought $340. A smooth bottom in nice shape is worth around $250 to $300. While a brass adjuster for a larger bench plane will work it isnt correct. Ohio and Stanley (as well as most others) No.2 sized bench planes have a smaller brass nut unique to them. There are several dealers that should be able to help you out.
