Shoulder plane use / technique
VTAndy4
>Hello,
I'd like to hear from those who use shoulder planes. How do you use your shoulder plane -- what applications and what technique for holding the plane? How does the design of the plane (including size) affect the range of uses of it? I don't intend this as a thread for comparing brands unless a key feature allows for a use that others would lack. I am also aware that some craftspeople don't use shoulder planes -- that's really a topic for another thread.
My use of a large shoulder plane is limited to fine-tuning the shoulders of tenons -- so it is really used as a "fine" tool, with a finely set mouth and a finely honed blade. It is not a tool that I am holding and using for an hour like a trying plane, so some of the comfort issues that have been brought up in the past have not seemed crucial to me. I understand that some people use this tool to make raised panels, but I have not tried that yet. A friend uses his large shoulder plane to fine tune rabbets cut with machinery -- he says he usually requires one or two passes. Does anyone use a shoulder plane to clean up a dado? (Obviously a job for a smaller should plane than the one I have.)
-Andy
Re: Shoulder plane use / technique
Hi Andy
I use a shoulder plane in just about every piece of furniture I build. I can, and have, adjusted shoulders of tenons in a number of ways, but a shoulder plane does this more easily and with greater precision than any other tool.
Below is a twin tenon that needed adjusting so that they lay in a coplanar line - both sides and both ends. I could not have done this without a shoulder plane since both needed to be trimmed at the same time.
(ignore the glue on the tenons - I only thought to take a photo just before it was glued up).
I do not usually use a shoulder plane to trim tenons, unless these are narrow, since they are poor at registering. A rasp, file or Stanley #140 is easier.
Wide shoulder planes, therefore, have an advantage in this regard - but, of course, they are less controllable for small work.
I am sure that there are many ways to hold a shoulder plane. This is how I hold the LV Medium:
No. I may use a router plane to do so, but I do not see the floor of a dado to require precision work since it is covered and not seen.
I tend to use them...
Scott Burr in Ben Lomond CA
>One handed when doing shoulder work and trimming the ocasinal short tennon. I like the low center of gravity of Stanley's 90 series for trimming tenons, and taller ones (Records, LN's, etc.) for shoulder trimming.
I have used them to clean and tune rabbits (this is where the removable bull nose comes in handy).
I also have used them for dado bottoms in a pinch. This is done much better by a plane designed for that task.
Re: I tend to use them...
VTAndy4
>Thanks for the responses.
As far as the dado question goes, I'd really like to try out a dado plane but don't know anyone locally who has one, so I've been looking for a usable one.
