Removing twist before or after glue up?
markfromsacramento
>I'm glueing up three 6-8 in. boards for each of the four sides of a case. Each board has been edge jointed and sized to width on the table saw but is otherwise still not yet planed. Normally I would remove the twist with a hand plane before sending each of the boards through a planer and then glue up the boards. I seem to recall that Tage Frid sometimes glued up boards without removing the twist to allow the flat board(s) to pull out some of the twist when they were glued up. Then the whole glued up panel was flattened; doing it in this sequence would supposedly reduce the total amount of wood that would have to be removed thus keeping the panel thicker. I guess it would be analogous to edge jointing a 9 ft board to remove all of the bow and then cutting into three equal lengths versus cutting the board into three pieces first and then jointing. Has anyone tried this or does anyone have an opinion on whether it makes sense? I guess the real reason that I'm asking is that the boards are about 7/8-15/16 in thick rough and I'm not sure that I'll be able to get a 3/4in. panel after flattening each board.
Re: Removing twist before or after glue up?
Jim in Burlington Ont.
Alot of work doing big panels
>It's alot harder to flatten big panels than single boards. You can make a panel with a little twist flatten out when you put the cabinet together but the key word is a little.
Warren in Lancaster, PA
>I joint the edges and glue up before flattening the faces. I think for a skilled worker this is the most economical in time and also preserves the most in thickness. If you consider a board with twist, there are two opposite corners of the face that are high. In flattening the board with a plane you can plane down one corner or the other or some of each. If you flatten before gluing you take away the freedom to decide how much of each corner to remove- you may have removed some that you would like back once you see it glued up.
There are a few reasons you might want to go the other route. It takes less skill to joint the edge if you have a flat face as a reference. Also if the boards are planed to near their final thickness you can see better what they will look like for laying out your panel.
