Workbench {Long}
>I have been doing woodworking professionally since 1972 and shortly thereafter I made my first workbench which was very utilitarian and somewhat crude. Since then I have built 8 workbenches and I finally got it right in 2003 when I built the bench which I have now.
This will probably be my last workbench, unless someone buys this one too. Four of the benches were similar in that they do not have tool trays. My first, second, third and seventh did not either. My last also does not nor does it have a vice.
I have had almost every type of vice on my benches, from wooden thread tail and face vices to metal vices of every configuration. My last two benches do not have permanent vices, but had a wooden patternmaker�s vice that attaches to holdfast holes in the top and apron. Nor do they have tool trays, a waste of bench top space and it just accumulates crap and shavings and sawdust.
I also have a small metal working vice attached to a piece of maple that I secure to the bench top with a holdfast.
I have a joiner�s bench with a front apron with holes for pegs and holdfasts. Pegs, wedges, jamb cleats are what I use to hold my stuff to the bench. This is probably the most simple of bench designs that does its job and does not get in the way.
I have had a grease cup under one edge of every bench I have made. A good recipe is 30% tallow and 70% beeswax. I use it for lubricating nails and screws.
I have a shelf on the lower leg stretchers and it is also full of crap. I have a separate cabinet in which I keep my tools as well as shelves on the walls and stuff hanging on the walls and of course the flat horizontal surface of my bench doesn�t ever get cluttered. Well all but the last part is true. Keeping my own personal bench clean is difficult because I also have two other workbenches in my shop (which I did not make) on which I do a fair amount of work. They both have tool trays which are also full of crap. I am planning on filling those crap holes with boards flush with the bench top and see if that helps. If it is there you will fill it.
Stephen
