5.5 C bed ID
David Churnega
>Can anyone ID the type on this 5 1/2. I need a tote that will fit the appropriate type.
David
5.5 C bed ID
David Churnega
David
Pretty sure that's an Ohio Tool
Neal in San Jose
>I pulled the front knob off of my #6, and the boss looks identical. I then checked a couple of 4 1/2, and the lettering (numbering) is the same. There were a couple of other manufacturers that used the "O" prefix; Record and Sargent, I think, so I could be wrong, but I'd put my money on it being an Ohio. Good luck finding the rest of the parts! BTW, Ohio blades are very good, and you won't gain much if you switch to an aftermarket blade. HTH Neal
Re: Pretty sure that's an Ohio Tool
David Churnega
>Thanks someone else also confirmed it was an Ohio and just happened to mention the exact same thing you said about the blade.
David
