Gluing leather to wood...
Scott Burr in Ben Lomond CA
>Hi All,
What's a good glue to use for this application. I'm looking to glue some leather on vice faces and making a strop or two.
>Hi All,
(Cow)Hide Glue..Of Course!!
Andy Lincoln,In Dearborn MI
Re: Gluing leather to wood...
Greg B�tit, Crown Point, NY
>I used some RTV compound (like silicone caulking) on my leg vise face because I knew I would want to remove & replace the leather eventually. That was before I set myself up to use hide glue. That is clearly the best choice. Of course if you're not looking at replacing the face ever, almost any wood glue would be good.
greg
Ian Smith (Sydney Australia)
>I made a strop by glueing a piece of leather to a piece of MDF using Titebond Original Wood Glue. It worked OK.
Regards,
Ian.
Adam Cherubini
>I think you should use 3M's contact adhesive of the sort used for headliners in cars. You can get it at your local auto supply place. PVA is going to give you neither the strength nor the coverage you're looking for. Hide glue would be too brittle I would think. I used this stuff to glue a relatively thin piece of suede to a piece of mdf for a strop many years ago. What I was doing with scrap mdf I can't recall! I do remember trying to plane it though!
Adam
P.S. No, I'm not kidding.
Ditto to 3M
>I also use 3M spray contact glue. Have for years. It is great - easy to apply, stable, tough.
Below are two leather strops, one is from Joel at TFWW, a horse butt (has Veritas green rouge on it), and the other is a hard barber's strop I bought on eBay (even harder than Joel's) that is used plain.
Like Andy said
>Hide glue is the answer for this and every other gluing application.
Hide glue has an excellend bond to wood and of course it holds well to hides.
If you are worried about it being too brittle, put a drop of glycerin in the glue before using. This will keep it flexible.
Stephen
Are you guys talking about...
>Scotch 3M super 77? The perfered adhesive used for scary sharpening.
Thank you!
That's it!
Adam Cherubini
Although in the 18th century...
Frank D. in Montreal
>It was Super '76.
Got it. Thanks Adam!
