Old Wooden Jack plane ID?
Dominic Greco in Richboro PA
>Hi everyone,
While this does not rank up there with many of the fantastic yard sale finds that members often post here, I think it's still cool.
I was on my way to Lowes on Sunday when I came across this yard sale in progress. In a plastic milk crate there was this beat up old wooden jack plane.
Old wooden jack plane
Base, wedge, and iron of old wooden jack plane
When I asked what they wanted, I was told "Eh,....$5." So I forked over the money and left with a plane, that at minimum will look cool on my book shelf.
But I'm sort of curious to it's origins. I cleaned it up with some Murphy's Wood Oil Soap and took some photos. The insignia on the iron loosk familiar. But I can't seem to find where I've seen it before. Does anyone recognize it?
Insignia on iron
From the stamp on the front of the plane body that is almost identical to the one on the iron. From this I would assume that we're talking about an manufactured handplane as opposed to one that was "shop made". Is that a correct assumption?
Partially obscured insignia on front of plane
I'll be honest with you. This plane is is somewhat sad shape. The tote has been broken off and is long gone. The chip breaker and iron are rusty, but not hopelessly pitted. Some home handyman ground a terribly steep bevel on the blade. I would need to regrind this carefully before re-honing. Plus the chip breaker looks to have been ground. The front of the body has some stress cracks. But they are only on the surface. And the wedge looks like it was chewed on by a mad dog. In addition, the throat opening needs to be patched so that it isn't as wide.
In other words, it's perfect to restore!
I've been reading David Finck's "Making and Mastering Wood Planes" as well as Michael Dunbar's "Restoring, Tuning & Using Classic Woodworking Tools" so I guess I got the "bug" pretty badly. I've had the idea to make my own hand plane for a while. I believe this could be the perfect project to get me started in that direction. I mean, what could be the worse that could happen?
What do you think?
See ya around,
My ugly mug
Dominic
Re: Old Wooden Jack plane ID?
It's all about thick shavings!
Wiley Horne--So. Calif.
>Hi Dominic,
Do a Google search on 'H. Chapin Union Factory' and read all about it. Should find some old photos of the Union Factory, also. An illustrious name in New England plane manufacturing. Looks like a W. Butcher Cast Steel iron, double iron at that. Is that a steel strike button at the toe?
The mouth looks great! Don't make it any finer. When you fix the blade up, put about a 6" radius camber on it.
Union Factory planes are prevalent enough that you might find someone with an original than can post the tote pattern and tell you how it was fixed.
Congratulations.
Wiley
Re: It's all about thick shavings!
Ernie Miller
>Looks like Whiley gave you most of the info that you need. These planes were used on soft woods for the most part so the mouth is fine. I can take a picture of a tote and even do a tracing if you want. I think they were glued in with hide glue. this one either got real hot or wet and poped out. should be an easy fix. I would jsut lightly lap the sole and sharpen the blade after making a tote it should work just fine. Some one used a steel hammer to set the blade instead of a wooden mallet that is why the wedge looks like it got ate. still it isn't to bad so I would use it as is. That blade is good steel enjoy. Unless you are going to make some pine chest's or somthing I'm betting it will be spending time on the book shelf as you will get better users for hard wood soon. I'm suprised they didn't have $25 or something like that on it people in garage sales think these planes are real old and rare making them worth lots of money when in fact $5 is about right for it. yous looks to be in better shape than alot that I see so enjoy.
Email me off line
Dave Anderson Chester, NH
>I'd be happy to take a tracing of the tote on my 28" Chapin Union Works jointer with Butcher iron. The mouth is still open after 150 years in our family and it still takes fantastic shavings with the original iron. I also have a 24" fore plane by the same maker that works just as well.
Slip sliding away...
Scott Burr in Ben Lomond CA
>Down the slippery slope Dominic slides! Yep, you got BAD!
As stated that's a W. Butcher iron. It's a nice laminated iron.
Follow Wiley's advise and you'll have a nice user jack plane.
Re: Slip sliding away...
Todd O. Cronkhite Maine Native, Presently Away
>Hey Dom, you seem to be spending alot more time here lately, what happen somebody steal your lathe? ;~)
I think this plane will make a fine candidate for restoration, and hey you'll also get to spend some time shaping out a new tote.
T.O.
Quiet past time
>Todd,
I still have my lathe but I'm finding that recently I prefer to work in a more "quiet" fashion. Namely, while my daughter is sleeping! :>)
Actually I've always loved using hand tools. My lathe work just over shadowed them.
See ya around,
Dominic
Thanks Wiley!
>I appreciate the input. And yes, there is a strike button on the top.
I can't wait to tune this up plane and get it working.
Dominic
Thanks everyone!
I appreciate all the input, suggestions, and useful information you've provided!
Thanks again,
Dominic
Re: Thanks everyone!
Bart Leetch
What do you think?
Well my old BP days friend you could end up with a older plane that works. Here let me throw you a rope & help you on down here step along lively now we don't want to slow down your progress.
Re: Quiet past time
Ernie Miller
>Ha DOm you know what you need? it's one of the MF cigar shaves to shape that handle. and maybe a set of rasps? or how about making a bow saw to cut it to shape. gonna need a set of brace and bits to drill them holes. I guess you better hit the garage sales this weekend.
Ha!
>Ernie,
You wrote:
"Ha Dom you know what you need? it's one of the MF cigar shaves to shape that handle. and maybe a set of rasps? or how about making a bow saw to cut it to shape. gonna need a set of brace and bits to drill them holes."
Way ahead of you champ. I got my Saturday morning pretty much planned so I can stop by the local flea market and check to see if any old tools are for sale there. Along the way I always run into at least 1 yard sale (weather permitting).
I think I'm probably gonna' stick with my drill press when it comes to making holes. And I'm already collecting spoke shaves. I have (2) old Stanleys that need refurbishing.
As far as the bow saw goes, that might be a problem. I'm saw challenged! My hand saw skills are not what you would call highly refined. I think I'll stick to the bandsaw,.....for now.
See ya around
Dominic
