Re: Skew Chisel Sharpening *LINK*
Brent
>If you are prepared to make a wooden jig, you can probably adapt the design of my slanted jig to your problem.
You will have to spend some time on the jig extension page to figure out the appropriate jig angle for the chisel size. For example, if the metal bit is only 2" long and you can only have 1" in front of the jig, then you will need a jig angle of around 35 degrees. But you will have to check the actual extensions possible for your blade.
If you dedicate the jig to the chisel, you can slot the thin jaw to hold the chisel at the desire angle. Usually this is not necessary, since wood seems to grip metal tools pretty well. You can make the jig without slots, adding them if the chisel slips.
Brent
http://www3.telus.net/BrentBeach/Sharpen/jigslant.
