Newest Tool Storage System
Todd O. Cronkhite Maine Native, Presently Away
>The only thing that is constant in my shop is that nothing is constant. I have been working none stop to come up with a tool storage system that I like. I came up with this drawer system a month ago, which I like, than thru a happy brainstorm I realized that I could put these drawers under, and on top of this bench and thus clear up the floor space that I showed earlier this week. This tool bench is sitting on the bump up of my two car garage, which I always considered to be lost space, so finding a use for this space is an even bigger bonus!
Now, this storage system is not yet complete, it is in fact at the dangerous point of being functional to the point where I can finish it at my leisure--and we all know what that means. ;~)
Another beauty of this design, is that I intend to put lids on the larger drawers, but leave them off until for whatever reason I need to relocate them, such as hurricane evacuation, or moving. At any rate, I'll put the lids on and be able to carry each drawer like a toolbox.
Yes, the planes are sitting on their soles, which isn't healthy for the edges, but to fix that problem I'm going to cover the bottoms with some tight weaved carpet that I've scavenged out of the trash.
I also intend to enclose the upper part of the bench just as the bottom is, but for now--it's functional. ;~)
T.O.
Re: Newest Tool Storage System
Marv
>WHAT????!!...No dovetails??
>HA! Dovetails?! Heck no, at the rate I go thru tool storage systems I'd be crazy to make any fancy joinery on them until I settle on something permanet. Until then, it's all butt joints and dry wall screws.
T.O.
Kevin French
>So what you're saying T.O. is like me You spend more time working ON the Shop and not enough IN the Shop.
Looks pretty nice from here !
s.mackay@worldnet.att.net
Todd, your problem
>is too many tools. There's a cure, but curing you would involve making me worse...
>Yeah, that seems to be gist of of ww'ing exploits. Spent most of the day modifing my benchtop! It was 36" wide, right now it's 18", and hopefully sometime tomorrow it'll be 24". Pics when I'm done.
T.O.
Re: Todd, your problem
>Yeah Bill, you're right. Some of those drawers are full of duplicates that I guess I really don't need in the shop, but I sure do like having them there.
One of the changes I'd make to some of the drawers would be to make them wide enough to place a #4 in from side to side instead of end to end. I could get alot more planes in one drawer that way. I had that Grand Idea after I had everything cut to size. }:~[
T.O.
Re: Todd, your problem is Hind Sight
Bart Leetch
>"One of the changes I'd make to some of the drawers would be to make them wide enough to place a #4 in from side to side instead of end to end. I could get a lot more planes in one drawer that way. I had that Grand Idea after I had everything cut to size."
Hind sight is a wonderful thing as your finding out Todd
>A good shop always has more tools than you know you have. It's like Christmas in July, looking for a tool and then finding one you didn't know you had.
Kevin French
>Ain't great, my shop has been continuosly updated for the three years I've lived here, based on the latest and greatest piece I've found. But it is coming to an end, but then I thought that 6 months ago also.
I'm in the procees of rehab'n a cart I found. I need a bench I can attach a saw vise and my Zylsis Vise(s) to. the Apron on my bench is too thick. This piece looks (almost) as bad as JR's Bedrock but it's shaping up.
Kevin, mount your saw vise to a wooden base that you can in turn clamp to your benchtop.
As for the zyliss, let me know what you come up with.
T.O.
Ernie Miller
>Time to hit the Flea market or have Keven send you a box of kitchen cabinet door and drawer pulls for all of them drawers if you get the handle type you can put one on the front and back for when that Evac to Mane comes up and you can carry them to the truck easily. I thought all of them LN were kept under the bed?
Ummm Todd
Scott Burr in Ben Lomond CA
>36" to 18" now back to 24"!?!
I think 36" to 24" could have saved you some (a lot of) time...;^)
Looks nice Todd...
>I'm wondering if putting the planes on carpet is a good idea, it seems to me that in a humid enviorment like yours it could be asking for trouble. I could just be worring too much also...
Paul in NJ
>Todd,
Glue a strip of wood ~1/8" square across the drawer at near the toe or heel end. It will raise the sole enough that the blade edge won't make contact with the bottom of the drawer.
Paul Dzioba
Re: Ummm Todd
Yeah I'm hearing ya' Scott, but I had to tear it down to 18" than build it back up to 24" in order to redo the slot for sliding board jack, which I finished this a.m.. The final benchtop demension is now 22 1/2" instead of 24". I wonder how this Grand Idea will bite me in the bum down the road.
Tomorrow I'll start altering the base to fit under the narrower top.
Even tho it's not yet finished, I can tell that I'm going to like the 24" top alot more than the 36"'er.
I was also going to shorten it from 6' to 5', but have decided to wait on that. One change at a time I think is the best route, as once it's cut it awful hard to put it back on.
T.O.
>No Ernie, I think I'll just make up some type of simple wooden pull/handle.
no, the LN's have been out from under the bead for about a year now, coarse, they haven't seen much action other than being moved from one tool chest to another.
T.O.
well then, I have a Good shop! ;~)
>Yeah Scott, I thought about the carpet/humidity/rust problem, but than decided I'd go with it anyhow and keep an eye on things. If it turns out to be not such a good than perhaps I'll try something along the lines of Paul's suggestion. Time will tell.
Thanks for the concern tho.
T.O.
"RJ" Whelan
>Todd .... pretty neat.
You might want to reconsider the carpet though - if it's terribly humid the carpet can trap a lot of moisture and end up rusting the soles of your planes - DAMHIKT. After years of tinkering I found the thing that works best for me is a little piece of 1/8 square molding glued down about an inch from the toe, or heel, of the plane (raises the plane just enough so the iron doesn't touch).
Have fun with the never ending quest for the perfect tool storage arrangement - I've been at it for over 50 years and haven't arrived at storage nirvana yet myself ...... rj
Ahhhhhhhhhh well then, that explains why after numerous attempts and coming up with the bestest tool storage system I've never constructed anything that really satisfied me. It dosen't exist!! DOH!
This current system satisfies me the most tho, as once completed the larger boxes can be taken out of their cells and used for transport cases.
T.O.
Hmmmm, I cut that top twice...
>and it's still to short!
Why do you think you'll like the top better at ~24" than 36"?
I'm curious because my bench "still on the drawing board" will be 36"
Wider is not always better
wilbur
>If the width of the workbench is too wide, it becomes difficult to go to the other side of the workbench and still be able to work with your piece comfortably.
For example: you are working on a cabinet door that's about 16" x 24". You're doing a glue up, and would like to adjust the clamps on the opposite side. With a 36" wide bench, you'll either have to go to the other side and reach across 12" or so to work on the other side of the cabinet door, or spin the piece around, in which case that extra width just isn't being used.
Wide working areas are probably good for assembly tables for large cases, but this assembly table would also probably be lower to the ground, and wouldn't be at a useful height for a workbench.
