Leg vise screw is oblong
Jack Guzman from Maine
>I got a real nice large leg vise with a 2" wooden screw at a salvage yard. It needs a little rehab(the jaws are beat up)so I took it apart. Plus I want to clean it up a bit and wax it.The screw runs fine until it gets to the end 4 or 5 inches.Here it binds every half turn.This section has no wear but it is no longer round.It is oval.The screw is dead straight so that's not an issue.I waxed it up and managed to unthread the whole screw.
I wonder if this condition is permanent.I know the shape is caused by cell deformation but is it reversable at all?If this is permanent I'll probably just take a rasp to the high spots so it threads easier.
So,anyone have any ideas? thanks ----Jack
Re: Leg vise screw is oblong
Paul in NJ
>Hi Jack,
Perhaps that end of the screw absorbed or lost moisture by some circumstance of its storage. Whenever I get a new wooden plane, I like to let it acclimate to my shop a while before I do any fettling. Why not let it sit for a while and see what happens?
Paul Dzioba
>It was stored in a trailer piled up with rusty tools,old file cabinets,broken furniture,etc..I imagine it got pretty damp in there.I'll wait for sure.---Jack
John Aniano, in NJ...
>Hello Jack,
Although Paul's suggestion is appropriate, might the oval cross section be caused by the differential shrinkage of the wood over time? If turned bowl can become oval after many years of drying, why not a wooden vise screw? Taking off the high stops might certainly do the trick, but I'd wait a few days to let it equalize to your shop's environment before getting out the rasp...
Take care,
John
Warren in Lancaster, PA
>I have a dogwood bench screw with a white oak nut. It was made in 1977, given to me in 1979 and in heavy use since 1980. The screw or the nut might have been a little green when made.
The vise runs smoothly for the first four inches, then has a little resistance and becomes increasingly stubborn after six inches. This corresponds to my use; there was even resistance over the length of the screw when I got it. The screw has been completely apart only twice since 1985 and today I'm sure it would be extremely difficult to unscrew the last six inches.
From your description, Jack, I think my screw has the same properties as yours and is more extreme. In use, it makes no difference that I can't get it all the way apart.
Adam Cherubini
>First, try moving the nut to the back side of the leg. The nut needn't be close to the vise jaw. My screws aren't even threaded for the 6 inches closest to the head.
Second, if you feel you need to make a change, for heavens sake don't make the deformed section round. You'll loose too much thread contact. Instead, make a little gauge of some kind the size of the major diameter. Don't take off any more than you need to. Also, beware these threads. With a full circumference, they will be prone to chipping.
If worse comes to worse, cut the head off, turn the threads down to the minor diameter, and let that into a new head. You will need to cross peg and I would recommend epoxy in this joint.
Adam
correction
Adam Cherubini
>I meant to write, without a full circumference of contact the threads will be prone to chipping.
>Thanks Adam and everyone else.
The screw is only warped at the section farthest away from the head.The only time it is a problem is when removing the screw,which will probably never happen again.I'll wait awhile and then take off the high spots just enough so I don't have to force the screw back on.
I have another leg vise that is quite functional,but it has a sloppy steel screw mechanism.Black pipe handle.Great holding power but ugly. This new vise is just pretty. Probably use it for more delicate holding.Leather jaw faces maybe.---Jack
The old one is red oak with maple jaw inserts. The new one is a smoother grain,lighter,not sure of the species. Maybe beech or maple.
