Thin High Density Plastic pieces
Todd O. Cronkhite Maine Native, Presently Away
>Discovered this the other, ot truth be told I think I re-discovered it, but on the cardboard boxes of laundry soap powder--well Cheer anyhow--the is a plastic handle, and BEHIND the ends of the handle is a small retangualer piece of what appers to be that very slippery high density plastic. Unfortunately it does have a hole smack dab in the middle of it, but still, I'm sure that uses for it could be found around the shop.
I found this because I was cutting a box off at a 45 degree angle to be used as a container for a few small bits of wood that I wanted to contain.
T.O.
Re: Thin High Density Plastic pieces
Adaptive reuse in the shop
Jim Reed @ Tallahassee
>I like your Yankee ethic. My shop is full of product adaptations. I save water bottle crate bottoms and use them like shop carriers. I use the large kittie sand buckets for lots of things. They are water and moisture proof and easy to carry & stack. I use cottage cheeze containers as disposable containers for paint and stain. The list goes on and on.
