REAL MILK PAINT
Talk to me about Stanley 180 Rabbit planes
Dominic Greco in Richboro PA
>Hi everyone,
A couple years back I acquired a Stanley Rabbit Plane. I never really used it and stored it away in my tool cupboard. Recently when I was cleaning up that area, I came across it again. Curiosity got the best of me so I pulled it out to examine. The sole is in great shape and I have (2) irons for it. The body features the words "No. 180 STANLEY" cast into it. And right underneath it are the words, "PAT'D 6-7-10".
I went to Patrick's Blood and Gore and read some there. I also looked in "Antique and Collectible Stanley Tools" and "The Handplane Book" and got some more information. However, they describe an "adjustable depth stop", which this plane is missing. I'm curious what it looks like and how hard they are to find.
My main goal is to see if this plane is "sell-able" in the condition it is now. Or if I need to find the depth stop. In which case I may just keep it (depending on the amount of effort it takes to procure said depth stop).
Thanks in advance.
See ya around,
My ugly mug
Dominic
Re: Talk to me about Stanley 180 Rabbit planes
ernie miller
>I have sold several over the years they are the same as on a 78 I think so you should be able to find one do a search on flea bay and see what the compleated auction prices are you will get your answer there I think I got in the area of 20-25 for a depth stop and thumb screw
Nice plane
jim reed @ tallahassee
>The 180 rabbet is a nice plane to use. Not as handy as the 78, but helpful. Without the depth stop, it is a door stop. A depth stop scrounged from a 78 or ordered new from Stanley parts would add value and utility to the plane.
OK,....so
>Jim,
You guys are making a good case for me to keep this plane. A reply on SMC's hand tool forum from Clint Jones gave me a pdf that contained the part numbers for a replacement depth stop. I think the total was $10. So that is a no-brainer.
But one of the reasons I never used it was my uncertainty on where and how to use it. How do I learn to use it properly? Is there some kind of article I can look at? Or book?
Later,
Dominic
Personally...
Scott Burr in Ben Lomond CA
>I'd ditch it and get a 78 or even better a Record 778 or even better a 289, but that's just MHO
What I don't about this plane is pretty much everything about it. It has no depth adjuster, no nickers, and most of all no fence. Pretty worthless as a rabbit plane, again MHO.
Get a copy of a book called "Planecraft". It was orignally produced by Record tools and features the use of their planes. It's a great referance. You should be able to find it at the libary, or it's available on line for purchase.
Disagree, except for the part about "Planecraft"
>Anyone who wants to know how to use metal planes should own a copy of "Planecraft." It's cheap, still available new from Woodcraft for about $10 last I looked, and comprehensive. Yes, you have to get past the British writing (not hard if you're British, I imagine, but a chore for many Americans), but it will reward study. When I first got it, I read through it about four times, and, 30 years later, I will refer to it.
If you don't own any other rabbet plane, Dominic, this will be a good starting point - after all, you don't need to spend money to buy it. I use my 78 without the fence and without the depth gauge frequently, when I need to correct an existing rabbet, or (more often for carpentry in this case), when I need to cut a rough rabbet or plane something down that is up against a surface. You can tack battens on the stock for width and depth of rabbet. For gauging depth, you could also just use a marking gauge to set your depth, and plane to the mark. If you do buy a copy of "Planecraft" (by the way, buy directly from Woodcraft, not from the online booksellers - the book tends to be more expensive used than new!), look at the discussion of the No. 10 bench rabbet plane for an idea of how to use a plane without a fence and depth stop.
Rabbet planes are handy
>if just for cleaning up after an electric router. No need for fancy attachments when you are just trying to clean up a joint.
Jim, what;s an "electric router"?
Todd O. Cronkhite Maine Native, Presently Away
