THE WOODRAT IS BACK!
Yet Another Saw Bench
Paul Kierstead
>Some of you probably seen this elsewhere, but thought I would share anyway, so bear with me.
This is yet another saw bench based on the Woodworking Magazine article. Hand tools, bandsaw and thickness planer employed. I learned lots (some new mistakes and some new techniques) and it is extremely sturdy and useful so far. A great project. Made from some stained (i.e. some natural grey/blue staining) poplar I got on the cheap.
Now I need to get rid of that awful saw and replace it with a new one. ...
Re: Yet Another Saw Bench
David Churnega
>Very nice, I plan on making that one too.
How did you cut the ripping fish tail so neatly?
Bandsaw & Spokeshaves?
Thanks for any additional information you can provide.
Dean J in MN
If Paul's saw bench ends up like mine -- don't worry about the neatness of that cut. It will be loaded with rip saw kerfs in a short while. :)
-Dean
Paul Kierstead
>Ah, well, pictures you know....
First I made a half template using some 1/4" plywood using a bandsaw and spokeshave (yes, I used a spoke shave on plywood 'end grain', works amazingly well). I made it as fair as I could. The drawing was done with a tension bow thingie. I transferred the template to the top and bandsawed it out, no clean up. A bandsaw can leave a reasonable surface if you are going slow. In this case, on one side I went slow and tried to be 'instinctive' ... just go with it. I missed my line by a fair bit (say 1/8" or so). That is the side you can see. The finish is not polished, but more then good enough to be interesting at least. The other one I got a little pig headed about sticking to the line and it resulted in a less-then perfect finish since I was manipulating a little too much. I might take a swipe or two with a spoke shave to make it look better, but oddly enough once I forget to look for it it still doesn't look too bad. The two sides don't match (due to missing the line on one and not the other), and I was all prepared to fix that but inadvertently wiped out the line finish planing the top. Then I realized you couldn't tell anyway ... the eye expects them to be the same and seems to let it be. I am a perfectionist by nature and hand tools are slowly teaching me to focus the perfectionism to where it matters.
Todd O. Cronkhite Maine Native, Presently Away
>Nice looking bench Paul. I'd of never thought of putting a birds mouth into one that's for sure. Which issue of Woodworking Mag was this in. Nice job on those mortice and tenons too!
Ah yes, the ol' Perfectionist problem, boy, that can be deabilitating. Perfection is always strived for, but rarely achieved. Learn to accept that whatever you did, it was to the best of your abilities at this stage of your woodworking persuits, and just strive for constant improvement is my suggestion.
T.O.
Thank you both for the motivation "NM"
David Churnega
Marv
>After many frustrating years of striving for perfection I finally came to the conclusion that it's a myth and the word should be stricken from the english language. I couldn't even guess how many hundreds of hours I've wasted trying for that last little bit that might make it perfect and sometimes making it worse. Few people ever notice that part that makes it near perfect anyway. You are usually the only one who ever knows and even then you'll forget about in a short time anyway. Be happy and proud of what you do and accept imperfection as being good enough so you can get on with the next project. You can consider yourself good at what you do when you get good at covering up those imperfections. Lots of products on the stores shelves that were invented just for that purpose.
