How to use a power jointer
ThomD
>"As I posted in the main forum, I should have picked a better title for my question. I wasn't looking to start a hand vs. powered jointing discussion. I was looking for an explanation as to how important jointer table bed length is for a powered jointer."
The main advantage of the longer infeed tables is that they allow you to safely handle large pieces of wood. On the last maple workbench I built, I ordered 3" stock, and it came in long pieces 8 inches wide. I expected to be able to run them over my jointer, but they were so heavy they were unmanageable, and the wood was brutally hard to plane. This was the event that pushed me to make my first
scrub plane, though maybe it should have been a coarse, Jack plane.
"According to every review I've read on powered jointers, increased table bed length is seen as a plus. In addition, I do have a Rikon 10" combo jointer/planer machine, which has a 40" bed and most comments that I have read about this and similar machines, like the Inca, have been along the lines of, "The bed is too short and it makes the jointer unusable."
Jointers work in a similar way to hand planes. You get a hollow or pretty flat surface in proportion to the projection of the blades from the sole of the plane/surface of the tables, relative to the length of the plane, and other factors (just fiddle with it). So a 40" jointer with adjustable tables (I had an Inca that wasn't adjustable for the outfeed, which is a little awkward) will have the same cutting geometry as an 80 incher assuming the correct adjustments are made to blade height relative to outfeed and infeed position. The issues becomes whether the machine is maintained well enough to take the finer cuts, and whether the operator wants to take more cuts to get to the same end point. This also answers your question about hand planes, they work with short infeeds because the blade projection is proportionately fine.
One unfortunate feature of American jointers is that the basic tool layout has not changed in decades, they don't have the more modern and effective guards that European machines have, and this make proper use difficult. The power jointer can be a very dangerous tool, you need to maintain the correct balance, and your hands must never be over the cutters regardless of the guard type or how safe the workpiece may seem. Be aware at all times of where your hands would be if suddenly the workpiece kicked out from under them.
Anyway, one thing that leads users to believe greater length is necessary is because there are all these pictures in books that show a square workpiece, fully supported on the infeed proceeding through the cutters fully supported on the outfeed. This is planing, not jointing or flattening. The workpiece is being reduced in thickness. It probably won't work as shown anyway, since the blades are set to overcut. It creates the false impression that the workpiece needs to be as short as the tables, or at least not hugely dwarfing the tables.
There is a lot of work that needs to be done that requires non-square pieces to be run over jointers, and it really doesn't mater what the size of the workpiece is as long as it is safe. The process proceeds like this:
- Identify the board shape, and any high or low points that need individual attention. You do the same thing you would do if you had an electric handplane, or a handplane. You serially attack the high points and try to get the piece closer to the final shape. The jointer does not need to be large for this, except as regards handling and capacity.
- Once you have your piece relatively flatter, set the cut and do midway hollowing plunges until the blade can't cut. You expand these until the whole surface, but for the ends, is hollowed.
- Then you set for final passes, full length. You can certainly induce spring if you want to.
So in summary the purpose of greater table size is to assist in material handling. There is not some magical minimum table size past which jointers work, and under which they don't. As with all power tools there are capacity limitations, and you have to decide what size of work you need to do in terms of material capacity and handling.
On thing that some people do with jointers is taper legs. This is a reasonably quick and repeatable way to cut tapered legs, with a series of plunge cuts. Obviously you need enough infeed to accommodate your leg design. This method can constrain you as to grain orientation in the legs. Just an example of an in-obvious capacity issue.
Jointers are like giant juicers. They have unlimited geometry from above the cutter head, on a vector towards the center of the arbour. You can remove your fingers, and with the right attitude the rest of your arm right up to your shoulder. Swing away guards do not fully protect against this experience.
